lumpy idle and battery light glowing?!!
Old Nov 18, 2009 | 06:43 PM
skypeller's Avatar
skypeller
Default lumpy idle and battery light glowing?!!
car is 1989 efi cvh XR3I with 99k miles
for a long time the car has run lumpy on idle and the battery light has glowed when driving even though the battery is in good conidition and the alternator has been bench tested by the local auto electricals, any ideas? not necisarrily linked but the mot guy said may be so
the fuel pressure regulator looks like its had a hole drilled in the bit that faces you as you look under the bonnet (wtf?)
had new leads and plugs
thanks for any help
Old Nov 18, 2009 | 08:46 PM
cabriolet's Avatar
cabriolet
the regulator is set by ford then capped someones drilled the cap to adjust the fuel pressure earths fella or iffy wire between starter and alternator
Old Nov 18, 2009 | 08:53 PM
skypeller's Avatar
skypeller
ahh excellent, i always wondered why that was drilled, its like the hole is enough for a small electricians screwdriver, would it be worth me getting another fuel pressure regulator and trying that see if it makes any difference to the engine running. its pulls pretty well jus sounds cammed on the tick over and i know its standard.
would a regulator from another efi be ok if it wasnt tampered with? any reason why some1 would adjust the pressure?
Old Nov 18, 2009 | 09:14 PM
skypeller's Avatar
skypeller
cvh efi dont have air flow sensor am i correct?
i used to know all this but not using the car for 5 years or so means ive lost my information memory on the old cvh
Old Nov 19, 2009 | 07:14 AM
You will get a good idea about fuel pressure by the mot emissions.
No you do not need a new pressure reg, just because someone has adjusted it, so long as the pressure is correct, the side where the adjuster is is the vacuum side, so if leaking fuel would be pissing out, there may be a minute vac leak but so small not worth worrying about.
Start with your basics, ignition timing, co at idle, is the idle speed adjustable, if lumpy only around idle look for air leaks first, especially on the pcv system, the actual pcv valve itself can jam.
As for the light glowing, if it's charging ok don't worry, just has tiny leak in a diode(one way electrical valve), there were bad batches of diodes years ago, mostly of US origin, but any earth that is sees on the wire between the alternator and the charge warning light will cause it to glow, if a resistor was put in line it would stop this if worried.
155lee
Sep 6, 2016 11:10 AM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
fuzzy
Sep 4, 2015 10:11 PM
