escort van 1.8d start
Old Nov 9, 2009 | 11:19 AM
GoldenBitz's Avatar
GoldenBitz
Default escort van 1.8d start
hi guys i noticed today with the cold weather it took my van ages to start its been serviced but im thinking would the heater plugs being changed be a good idea to stop this cold start problem or is it another problem thats might be casuing this it didnt do it during the summer so im not sure what to do thanks
Old Nov 9, 2009 | 11:33 AM
nellyscossy's Avatar
nellyscossy
always best to put a new set in
first check thay are getting power , put a tester on them and start it up, the plugs should live up (12v)and stay on for a minute or so after it starts
Old Nov 9, 2009 | 04:32 PM
Alvyn's Avatar
Alvyn
check that the main fuse for the glow plugs hasn't blown it's the RED one near the battery !
Old Nov 9, 2009 | 04:33 PM
As above check they are actually working, it's often worth giving them two cycles of heat first thing.
Old Nov 9, 2009 | 06:16 PM
GoldenBitz's Avatar
GoldenBitz
thanks Tab will try it in the morning i know its gonna be cold
Old Nov 9, 2009 | 07:01 PM
markk's Avatar
markk
valve clearances if the glow plugs work ok.
Old Nov 10, 2009 | 04:26 PM
How often are you draining the filter head of water ?, this will make it harder to start, as will a dodgy too small a battery.
I know when I had a mk4 escort 1.8D, the battery that was recommended by one battery maker was seriously tiny, and same as a 950 fiesta one, fine in summer, wouldn't even nudge the engine in the winter!!, fitted a mega whoppa battery of 980CCA instead of 330CCA, it spun over then!!
Old Nov 10, 2009 | 05:19 PM
GoldenBitz's Avatar
GoldenBitz
thanks tab might try the battery do you mean the fuel filer
Vincereese
Jun 1, 2023 09:14 AM
The Enigma
13
Aug 20, 2015 09:38 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
vdubo7
Aug 2, 2015 08:17 PM
