reversing lights not working, escort van wiring help needed
Old Nov 5, 2009 | 09:38 PM
jakemuk's Avatar
jakemuk
Default reversing lights not working, escort van wiring help needed
T Reg Escort Van,
Nice van runs nicely had a recon engine 5k ago, So just running her in, Problem i have is the reversing lights don't work either side, A mate has tested both sides with a meter and dead as a dildo,
So basicly i want to try and find out what colour in the loom is for the reversing light or what pins, So basicly i can connect directly to a switch in the front to put the reversing lights on.
Could anyone help me out with this,
Also someone has put a towbar and hacked into the wiring, Before i go the measure of hacking into the loom, I am going to rip out the trailer wiring and rejoin the original loom with butt connectors, That might actual fix it to ?
Old Nov 6, 2009 | 08:15 AM
If some total dick has cut the reverse light wire/s then it will work just re joining them, as you have a towbar why not fix the wiring to it, as towbars are very useful to have, and wiring easy to do.
I would find the two pin connector on the reverse light switch on the gearbox, this will tell you the colours, and you can also probe for a live at the terminal(ignition on), if you have a live there bridge the two terminals and see if the lights work, if they do it's switch, or adjustment of switch that is at fault.
There is no connection to a trailer socket from the reversing lights, certainly NOT on a std black 12N socket, one can be put on if it has a extra GREY socket as can rear fog, soon to be part of mot!!
Old Nov 22, 2009 | 05:35 PM
jakemuk's Avatar
jakemuk
An Update,
Sorry been so long, been busy with working, And put it to one side, Until saturday morning when the gear linkage played up, Quick visit to the breakers and £5.00 gave me a replacement linkage, And its bang on
Anyway back to where we are, I have found the reversing light switch on the front of the box, And the connection, Help from another thread on here, So how do i test it by bridging the 2 wires out ? Does the ignition just need to be on or engine running ?, If that works then all i do is simply get a new switch yeah ?
Old Nov 22, 2009 | 05:45 PM
Yes simply join the connections together with a piece of wire poked into the switch connector, ignition needs to be in position 2, normal running/driving position but does not need to be running, if all ok replace the switch.
Old Nov 22, 2009 | 05:59 PM
jakemuk's Avatar
jakemuk
Just done that and they lit up so new switch ?
Old Nov 22, 2009 | 06:26 PM
jakemuk's Avatar
jakemuk
Also forget to say do i need this up on axle stands / ramps. To do it ?
Old Nov 22, 2009 | 06:47 PM
martysmartie's Avatar
martysmartie
The switch is on the gearbox itself so yes best to jack car up, have you tested the switch as although it is almost certainly the switch, it may be the levers inside the box that actuate the switch.
Martin
Old Nov 22, 2009 | 06:58 PM
jakemuk's Avatar
jakemuk
Havent tested the switch yet, I have bridged it out tho and the reversing lights do light, How would i test the switch remove it ? and manual push it in ?
Old Nov 23, 2009 | 12:28 PM
Yep just remove and push, that's all that happens inside the gearbox, just hope it's not the box.
Old Nov 23, 2009 | 12:56 PM
jakemuk's Avatar
jakemuk
well if it is the box tabetha, I will just fit a toggle near the gear lever to be honest, Its not worth fixing the box for just that realy, It drives ok and well its a work horse van
CrOwSoN15
Aug 14, 2015 06:52 PM
col93saphcos
Aug 7, 2015 03:21 PM
turbobill
Aug 1, 2015 08:55 PM
Old ford
Jul 31, 2015 06:50 AM
