hey tech head's :)
Old Nov 2, 2009 | 05:23 PM
cabby3i's Avatar
cabby3i
i wish i was a virgin lol
Default hey tech head's :)
Hey guy's, i just bought a 1.3 escort ohv efi endura e, mk 6 '98, it was a bit rough at idle when it got hot , so i have whipped off the rocker cover and adjusted the tappets as per instruction on rocker cover, i.e
0.5-0.2 - 0.5 0.2 - 0.2- 0.5- 0.2- 0.5 mm, it run's alot smoother but is somewhat noisier, suggesting ware in rocker's or rod's, im wondering what is the maximum i could adjust them to compensate for ware?
would 0.4 and 0.15 work?? also some one told me the tappet's can be adjusted slightly to increase perfomance? is this true?
i would like to hear some profesional advice or tip's, what can be done in the way of tuning/increasing acceloration?
thanx in advance
Old Nov 2, 2009 | 05:32 PM
crazyshad1's Avatar
crazyshad1
they are really tappety and you can't get anymore power that way
Old Nov 2, 2009 | 06:47 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if you close the gaps down you'll get a bit more lift in the valves, but too much and you can end up with valve to piston contact, but you may get more performance.
you could open the gaps up a tad and let more oil to the top of the valve which may cussion the tapping a little more.
it could be a bit of wear in the rocker shaft assembly though.
Old Nov 2, 2009 | 11:24 PM
cabby3i's Avatar
cabby3i
thanks for the reply's guy's!! would using magnatec oil help?
Old Nov 3, 2009 | 09:42 AM
You can buy a tool called a clickadjust, this accounts for the MASSIVE wear these suffer from.
A alloy RC will be the best thing for noise.
You can also take the rocker gear apart, then turn the rocker shaft(180) so the left becomes right, and right becomes left, then ROTATE 180 degrees, then rebuild.
This puts the UN worn face lower most where the load is, done it loads of times.
When adjusting the clearances pull the rocker arm up to try to get any wear in it accounted for and adjust whilst still holding, running the valves closer will kill the performance, a slightly larger gap on the exhaust helps sometimes on these depending on how wild the cam is.
Old Nov 4, 2009 | 10:36 AM
cabby3i's Avatar
cabby3i
this is a push rod engine , no cam!!! so you say a alloy rc, any link's as to ware i can get 1 from?
the rotating of the rocker shaft is a good idea tho and will be getting done this weekend!
would a oil like magnatec help? the recomended is 5/30 semi synthetic? watery crap, would i better off using a 5/30 non synthetic oil
cheers for the reply's!
cabby
Old Nov 5, 2009 | 03:38 PM
I know it is a push rod engine, trust me it obviously has a cam, what do you think the lumpy stick(cam) is ?, this is lower down under the push rods that sit in a tiny bucket each that bears on the cam, no cam would be a problem!!
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
sridgett
Oct 1, 2015 07:30 PM
