bailey oil seperator help needed please
Old Oct 31, 2009 | 04:31 PM
craig66's Avatar
craig66
Default bailey oil seperator help needed please
i have fitted a bailey oil seperator to my escort rs turbo but what happens to the little breather from the manifold to the old seperator
Old Nov 1, 2009 | 06:58 PM
RS1HEN's Avatar
RS1HEN
this may help, just been here ourselfs:
https://passionford.com/forum/ford-e...seperator.html
Old Nov 1, 2009 | 08:31 PM
craig66's Avatar
craig66
did you try starting it without that connected if so what happened thanks
Old Nov 2, 2009 | 08:28 AM
RS1HEN's Avatar
RS1HEN
ours in already plumbed in, and seems to work???
we started a thread the other day as we had a few questions:
https://passionford.com/forum/ford-e...separator.html
no answer yet though
Old Nov 3, 2009 | 06:06 PM
craig66's Avatar
craig66
would you be able to put pictures up af your inlet manifold so i can see what happens to the one of the inlet manifold nearest to the drivers side please help
Old Nov 3, 2009 | 08:19 PM
RS1HEN's Avatar
RS1HEN
its not brilliant, its all i got at the mo
it goes round the back of the rocker cover and goes on to the furthest outlet from the rocker cover at the top, if this makes sense!
Old Nov 3, 2009 | 08:27 PM
craig66's Avatar
craig66
on the inlet manifold you have a little red pipe that looks like it goes to were the ecus are where does this go i have fitted it all right now just missing were that goes as some people block it others say no aint sure
Old Nov 3, 2009 | 08:53 PM
RS1HEN's Avatar
RS1HEN
both vaccum hoses, drivers side goes to boost guage, righthand side to ecu, and a t feed off to the dump valve
Old Nov 3, 2009 | 08:55 PM
RS1HEN's Avatar
RS1HEN
its not in the best place, i need to move it under the strut brace, will be doing it in areoquip soon
Old Nov 4, 2009 | 07:15 AM
craig66's Avatar
craig66
thanks mine all seems right is your metering unit pipe venting to atmosphere or blocked thats all thats left may put old one back on as wont run now lol and all piping seems fine thanks for your help how come no one else replies to these lol seems a very grey area
Old Nov 4, 2009 | 07:56 AM
RS1HEN's Avatar
RS1HEN
haven't really checked yet tbh,
would have thought it needs to go somewhere????
as any air that isn't regulated or leaks, may cause running problems:
https://passionford.com/forum/ford-e...ve-or-not.html
will be starting our "keep the thing alive" program on saturday, as it'll be a couple of weeks we've had it since then....
Old Nov 4, 2009 | 01:17 PM
craig66's Avatar
craig66
yeh thats what is happening with mine it starts then dies hoping if i put pipe from the seperator straight to the metering unit for now it will run as it starts then dies and all piping seems fine
Old Nov 4, 2009 | 01:42 PM
RS1HEN's Avatar
RS1HEN
have tou got a catch tank, with a vent to atmosphere?
sounds like theres a leak somewhere, try the OE crank case breather
Old Nov 4, 2009 | 05:19 PM
craig66's Avatar
craig66
no i havent i just got the seperator fitted to the both rocker ones and the crankcase then the one that either goes to a catch tank or back to the metering unit or someone said you can just vent it thats what ive done think im gonna put it back to metering unit for now and see thanks for the help
Old Nov 4, 2009 | 08:17 PM
RS1HEN's Avatar
RS1HEN
tbh it sounds like it is in right, are you sure you've got the 2 bottom hoses the right way round,
i think you'll find the passenger side one, is the one to atmosphere(catch tank)
if it is, then its something else. must be an air leak
Old Nov 7, 2009 | 02:11 PM
craig66's Avatar
craig66
just checked the car connected a pipe from the metering unit straight to were the catch tank should be and runing fine again thanks for the help i realy aprecciate it gunna fit my escort cossy wheels now should look mint
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
155lee
Aug 14, 2015 11:21 AM
Churtz
15
Aug 13, 2015 06:40 PM
col93saphcos
Aug 7, 2015 03:21 PM
