Focus ST170 funny noise?!?
Old 28-10-2009, 07:04 PM
24fanaticuk
24fanaticuk's Avatar
Default Focus ST170 funny noise?!?
Hi all,
Just signed up to the site and this is my first post
My partner and I have recently bought a ST170 ( I own the new ST and she wasn't allowed one that good!!) and we have recently noticed that when the car hits 3000 rpm exactly, in every gear, it makes a strange noise.
I can only try and describe this noise as a short, rattling, tinny, scratchy type noise. It is not overly loud, but loud enough to hear if you were driving normally and had no stereo on, but you dont hear it with the stereo even slightly on.
The only real problems we have had since we bought the car was the ECU light come on a little while ago, got that checked out and it was the Lambda sensor, no biggy, got that replaced and all seems to be ok now.
I only mentioned that in case it might have something to do with it, the only way I can possibly see it might have something to with it is because it is specifically at 3000 rpm and I know thats when the 'get me home' rev limiter stops.
I have asked a few people about this already and they hadn't a clue so I thought I would try on here.
If anyone could shed any light on our problem it would be much appreciated!
Thankyou in advance
Old 29-10-2009, 01:30 PM
Sp3no
Sp3no's Avatar
Could just be reverberance at them revs causing the heat shield to rattle. The ST170 cat has a couple of heat shields surrounding them, these get really hot a corrode so tend to come loose and rattle at certain revs. Get underneath and have a look, the Cat brackets tend to shear also and need welding. I would not be ovely concerned at this moment in time. Most likely the heat shield.
Some thing else i would check on the ST170 is the IMRC (inlet manifold runner control) module. Just as a matter of course. There is a silver box bolted to the fire wall at the back of the engine. When you turn on the ignition it pulls a cable which shifts the runner in the inlet manifold, then when you hit 5000+rpm it releases the cable and the runner goes into its second position. The cable is attached to the passenger side of the inlet manifold under the throttle body, check that the cable is attached and working as the level on the maniold tends to snap off. Just watch the cable as someone turns on the ignition, it should move the runner as soon as its turned. Any clicking sound coming from the bulkhead area will be the IMRC unit its self is knackered. these are very common problems. Along with jerky driving at high speeds and loss in power is usually a faulty fuel pump. The only other real BIG issue with the ST170 is the dual mass fly wheel, they die very quickly around 60'000, this will result in a new fly wheel, clutch, clutch cover plate and slave cylinder which will cost you £1000+ This will hapen at some point, my ST170 just his 59'000 and i just paid out £1000 to have the whole lot replaced!!
Good luck.
Steve Escos
Ford Focus ST Parts for Sale
02-09-2019 11:39 PM
dombanks
21-09-2015 08:38 PM
Tank Mike
10-09-2015 07:56 AM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
rsturbo27
05-09-2015 05:08 PM
Quick Reply: Focus ST170 funny noise?!?
