t5 gearbox problem
Old Oct 26, 2009 | 06:18 AM
1cosworth's Avatar
1cosworth
Default t5 gearbox problem
hi 2 all.got aquestion about my t5. i ve just change the old clutch kit with a standart new one (clu,plate and clu.cover). i run almost 1.0 to 1.2 max boost.is it normal with 5th gear to slip with the 1.2 boost.didnt have this with the old clutch set.i ve not done more than 400 miles with the new
Old Oct 26, 2009 | 08:46 AM
LHD220Turbo's Avatar
LHD220Turbo
was it a new clutch from Ford direct?
if so, then i am under the impression that the manufacturer of the clutches has changed and they are not good quality
Old Oct 26, 2009 | 08:51 AM
1cosworth's Avatar
1cosworth
Default t5 gerabox problem
i think they both are valeo items . is th clutch plate from the 2lt same as the cosworth?
Old Oct 26, 2009 | 04:04 PM
Even the std ford one should handle way more than this, does the pedal pressure feel lighter ?
Old Oct 27, 2009 | 06:09 AM
1cosworth's Avatar
1cosworth
tabetha yes it does feel much much lighter almost like driving another car
Old Oct 27, 2009 | 06:23 PM
The diaphragm is obviously much less clamping force, if you have the old one put that back on.
Old Oct 29, 2009 | 06:09 AM
1cosworth's Avatar
1cosworth
Default t5 gearboxproblem
hi tabetha again and thanks ,i dont know what the diaphragm is and where it is.
Old Oct 29, 2009 | 07:44 PM
The diaphragm or as some call it the pressure plate, is the outer part of the clutch, with the sprung fingers in it, the bit that actually clamps the friction disc between the flywheel and clutch diaphragm.
The diaphragm is inside the bell housing so will be a box off job, first though make sure it is not over adjusted by some numpty.
PULL on the clutch pedal, ie up past it's normal(rest) position, this will release any tension in the adjuster, then a few presses later will auto adjust to correct itself try that first.
Old Oct 30, 2009 | 06:17 AM
1cosworth's Avatar
1cosworth
ok i ll tyry that first and see what ll happen thanks for your time
Old Oct 31, 2009 | 02:12 PM
I'll keep me fingers crossed!
TPM961
Jan 15, 2018 10:50 AM
Flateric_2002
Sep 15, 2015 08:41 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
gingeRS
Sep 4, 2015 06:29 PM
