testing the fuel pump
Old Sep 26, 2009 | 12:16 AM
djchurch2001's Avatar
djchurch2001
Default testing the fuel pump
how do i test the fuel pump to see if its working correctly as mine does not sound its normal self
Old Sep 26, 2009 | 10:33 AM
Just apply voltage and see if it spins up, that's all you can do.
The pumps vary a lot in the noises they make from one to another, but if a particular pump has changed it's note from normal that is usually a sign it's on it's last legs, but could still last years!!
You could get the flow data and test actual pump output as well if you wanted.
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
kevin36
Sep 8, 2015 12:23 PM
hopper350
Sep 4, 2015 12:53 AM
