frst fuel down
By fixing whatever fault it has to make it overfuel, its not something you should need to turn up and down.
What spec is the engine and what chip is it running?
What makes you think its over fuelling?
Was it ok before and this has just started happening or has it done it since its last spec change?
escort rst cosworth rep
stander with ofac and blues
went on a sun exhaust machine and readings were high fitted a new co parameter and still the same and been told overfueling
na its been like this since ive fitted the engine loom and ecu
