Fitting OIL SEPARATOR on LHD Sierra Cosw. 4x4 with AC
Hi,
please help me. Where/how can I fit a Bailey Motorsport Oil Separator on my LHD 1992 Ford Sierra Cosworth 4x4 with AC? Link to picture of enigne is here:
http://cossie.tkrath.dk/grafik/ford....ept2004008.jpg
Hope you can help me
Btw. can you recommend the products from this supplier - http://www.autospecialists.co.uk/ ?
Thanks
Thomas Krath
Thanks
Thomas Krath
what you need is the oil breather system from spec-r,the seperator sits between your battery and the head and there is a catch tank that will go were your airbox is,you would need to remove the airbox and fit a cone filter check there web site picture of a cosworth engine bay
http://www.spec-r.co.uk/
Jep I know the spec-r breather system - looks really nice but is quite expensive
I have talked my mate and came to the conclusion that I should fit a breather system like his:
http://cossie.tkrath.dk/grafik/coswo...4x4.rene06.jpg
I will make a hole in the cover (which he hasn't on his) + use the std. breather hole from the bottom. Where should I fit the return hose?
Thanks
Thomas Krath
Thanks
Thomas Krath
the return hose should go down to a blank plug which you remove on the exhaust side of the block,its down near the sump under #4 exhaust outlet and is pointing upwards at a slight angle,there is another blank on the block above it but thats for the water jacket
I know this engine is from 2wd and mine is a 4wd, but I believe the blank plug can be found on them both? Is it no. 1 og 2 in this picture?
Thomas Krath
No.2 !
As a rule its better to return the oil into or below the oil level by tapping into the sump , its possible that what you use as a return re-pressurizes the crankcase . on a 4x4 sump there are a couple of places this can be done quite easily !
Originally Posted by Tony Ryan
No.2 !
Thomas Krath
Originally Posted by wimwerf
take mirror image tank...
Btw. what are the specs. of your car? T35 turbo??
Thomas Krath
use no.2, you will need a similar thread fitting as the plug you remove in order to put a pipe down to it and clamp it up,you may also need to put some heat protector on the pipe as it runs close to the exhaust,
Thomas Krath
Jack and the Beanstalk
15-08-2015 04:27 PM
