Running problems
Old Sep 19, 2009 | 07:02 PM
djchurch2001's Avatar
djchurch2001
Default Running problems
I have just dropped a turbo lump in my se 500 escort. The car starts fine but will not continue running its dies after about 3 seconds. Does anyone know what this could be?
Old Sep 19, 2009 | 08:16 PM
Could just be low idle speed, is it ok holding on the throttle ?
Old Sep 19, 2009 | 08:18 PM
djchurch2001
no not even holding on the throttle. Behind the inlet manifold on the loom there are about 5 different colour connections. do you know what colour goes on what sensor i have a feeling i have them the wrong way round
Old Sep 20, 2009 | 10:53 AM
I'm not familiar with this set up sorry.
It should be obvious what the sensors do by looking at them, maybe look up the sensor in the wiring diagram, then you will have the wire colour to each to get them right.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
