zetec conversion in mk4
Old 07-09-2009, 06:28 PM
martinmilne
martinmilne's Avatar
Default zetec conversion in mk4
i have a mk4 escort bonus which i want to give a power increase to was thinkin normal rs turbo lump but want it to be reliable and more economical so want to fit a zetec as there cheap to but i would like some advice to go about it im good with the spanners and have done engine swaps before but never zetecs so need to know wat i need and the best way to do it any help would be great cheers
wat engine ?
gearbox?
management ?
cooling system wat parts from wat cars ?
Old 08-09-2009, 07:48 PM
fonfe123
fonfe123's Avatar
dont mean to be rude but use the search this has been coverd loads of times which is probably why no one has replied.
Old 09-09-2009, 07:50 PM
martinmilne
i have but very vauge wat i found even looked up on your site just want to know the best options for the conversion
Old 09-09-2009, 08:56 PM
xrmalin
xrmalin's Avatar
Your better buying a complete donor car preferably pre pats then you will have pretty much everything you need
Old 09-09-2009, 09:57 PM
martinmilne
yeah i read that how do i tell if it got pats
Old 10-09-2009, 03:21 PM
xrmalin
xrmalin's Avatar
You'll have to take the steering columb cowling off and if its fitted with pats it will have a plastic transponder ring round the ignition barrel.
If i was you id try and find an early mk5 xr3i cabby as these are fitted with all the 130bhp bits
Old 11-09-2009, 07:08 PM
fonfe123
fonfe123's Avatar
check the key. red chip in the key means its got pats.
Old 25-11-2009, 10:07 AM
mk4 kabby
mk4 kabby's Avatar
if you get one with pats just tape the key to the ring and put it with the ecu under the dash.
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
01-11-2015 06:53 PM
SMILER258
28-09-2015 09:04 AM
mondeomark
28-09-2015 06:28 AM
Quick Reply: zetec conversion in mk4
