Battery Light Issues
Old Jul 29, 2009 | 11:33 PM
djchurch2001's Avatar
djchurch2001
Default Battery Light Issues
for some reason the battery light does not come on. i have checked the bulb but no issues there, what else could it be?
Old Aug 1, 2009 | 01:45 PM
lmmrst's Avatar
lmmrst
check the feed wire on the altenator is connected
Old Aug 1, 2009 | 01:48 PM
forevaford's Avatar
forevaford
no light - no charge,
check that the little wire is connected to the alternator, its colour is usually blue
Old Aug 1, 2009 | 02:11 PM
The alternator will still charge without the light working, providing the alt isn't duff, as it will kick in at higher revs and then stay in until stopped, so as a temp just blipping throttle will get it kicked in, but better to have working circuit of course.
You need to establish whether it is the just the bulb/wire to it or if it has stopped charging, connect a metre up before starting engine note reading, start engine then when revved high enough it will kick in and show a higher reading all of a sudden.
Sometimes it is just a crudded up connection on the alt IND terminal, the one where the thin blue wire goes.
Old Aug 1, 2009 | 02:24 PM
Neil S's Avatar
Neil S
Check the fuses at the front offside of the fusebox - one of these protects that circuit, might be F21 or F22
Old Aug 1, 2009 | 04:41 PM
RobertM's Avatar
RobertM
With a non running engine and with contact on ground the thin wire, the light should go on brightly, you don´t have to disconnect the wire from the alternator, just do not run the engine while you are doing this.
If the light comes on, the bulb and wiring are ok so the alternator must be broken, possibly brushes or rectifier.
Nov 3, 2015 04:08 PM
gingeRS
Sep 4, 2015 06:29 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
turbowag
Sep 3, 2015 08:07 AM
