88 erst missing
Old Jul 21, 2009 | 06:42 PM
andyjg79's Avatar
andyjg79
Default 88 erst missing
need a bit of help
runs fine under normal conditions
but on full throttle have teribble miss fire
let of the throttle a touch black smoke then its of
changed leads plugs dizzy cap arm
had turbo problem put a nother one on since then i have had this missing
smells like it is running slightly rich as i am taken her to spec one over the weekend any surgestions would be great will leave it with you all
many thanks in advance
Old Jul 22, 2009 | 12:26 PM
gtit's Avatar
gtit
sounds like mine 2! some one else said get it set up im gona phone up sitech today c wen hes able ta do it
Old Jul 22, 2009 | 12:32 PM
coswurv's Avatar
coswurv
Originally Posted by andyjg79
need a bit of help
You sure its not overboosting and the chip is cutting it out, thats why when you back off you get all the black smoke of un-burnt fuel.
Old Jul 23, 2009 | 12:13 PM
andyjg79's Avatar
andyjg79
how would i check for over boosting
as it is running 10psi according to my gauge
and i have no bleed valve on
Old Jul 23, 2009 | 12:42 PM
b_kennedy's Avatar
b_kennedy
Have you checked the timing? Sounds like its running rich!
Not a mechanic but had similar problems and it was timing. Would it be possibly an injector. Maybe dumping too much fuel. Maybe someone else can advise on that.
Old Jul 23, 2009 | 12:54 PM
antony215's Avatar
antony215
Escort Rs Turbo
Is it chipped??
If not then thats why it's missing. When you hit 10psi the boost will be cut buy the ECU if it's not chipped.
Old Jul 24, 2009 | 09:33 AM
andyjg79's Avatar
andyjg79
timing is bang on
its not chipped
was running this al day long before turbo went
put sierra cossy turbo on ever since had miss fire on full throttle
running slightly rich but nothing major
coould it be a problem with the air /fuel mix through air mass ?
Old Jul 24, 2009 | 01:34 PM
antony215's Avatar
antony215
Escort Rs Turbo
If it's not chipped and you hit 10psi the ECU will cut the ignition. Try turning the boost down and see what happends
Old Jul 24, 2009 | 08:13 PM
coswurv's Avatar
coswurv
As above a standard ecu wont have anymore than that till it cuts the ignition.
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Mc5506
Oct 5, 2015 09:57 PM
Fil
Sep 30, 2015 12:08 PM
beller
Sep 21, 2015 04:13 AM
