Mondeo TDDI
Old Jul 13, 2009 | 05:49 PM
kaking1982's Avatar
kaking1982
Default Mondeo TDDI
just after some advice i think my fuel pump has gone or my injectors. the car starts and runs fine a soon as i drive it its slugglish and pours black smoke out the exhaust you can accelerate through it but still down on power if you hold it at a constant speed the car surges as if fuell problem
thanks olly
Old Jul 13, 2009 | 07:11 PM
G420 DEL's Avatar
G420 DEL
try a new air filter. if its not been changed fora while they clog up with shite and cause such issues
Old Jul 15, 2009 | 11:37 AM
kaking1982's Avatar
kaking1982
changed the air filter and fuel filter im starting to think i have a split in an intercooler pipe seems only to happen when under load or when turbo coming in
Old Jul 15, 2009 | 05:52 PM
pieterjan's Avatar
pieterjan
Ypu have to look at you boost hoses from and to the intercooler. The hose that is located at the steeringpump (right side of the car when you stand for the car) they breake sometimes. yuo can get a repair kit for it at ford.
Old Jul 16, 2009 | 10:08 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Try the air flow meter. sounds like my old vectra
Old Jul 17, 2009 | 03:14 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Does it still boost up ok ?
Old Jul 17, 2009 | 03:17 PM
dan-dan's Avatar
dan-dan
it wont be a split injector pipe because it would not run at all
Old Jul 17, 2009 | 04:32 PM
B19 JUB's Avatar
B19 JUB
yeah id say boost pipe split.normally on mondeos its the pipe from the egr valve which is left side of engine that goes down to intercooler,it splits on the bend or the small boost pipe under the turbo at the back.that would definately give those symptoms
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
