MAP sensor mounting. Does it need to be earthed?
Old Jul 5, 2009 | 09:34 PM
muz's Avatar
muz
Wye Valley Hardcore
Default MAP sensor mounting. Does it need to be earthed?
My cars running a little rough and overfueling. I spoke to Graham Quick and he said it sounded like a dodgy MAP sensor to him.
I've just been looking at pics of me motor and I've noticed I've mounted the MAP sensor on the plastic heater box cover not on the chassis. Will this be the cause. Does it have to be earthed?
Old Jul 6, 2009 | 07:03 AM
I've ran them without being earthed to the chassis with no problem.
I can't make out yours in the piccie, but they do have to be the right way up, and are normally below the engine with bends in the pipe to stop fuel vapours getting in.
Old Jul 6, 2009 | 11:05 AM
muz's Avatar
muz
Wye Valley Hardcore
Its behind the inlet manifold leved with the FORD logo. The vaccum for it is the red piping whihc comes from the inlet and t's off to feed the boost gauge and FPR aswell.
Old Jul 6, 2009 | 11:32 AM
rst cabbie's Avatar
rst cabbie
gingeRS cabriolet
ive got mine on the heater box . but have run a wire to the battery earth just in case
Old Jul 6, 2009 | 12:10 PM
I did wonder if that was it, will be ok so long as in same plane as original, ie same way up etc it's vital, they have their own earth in the 3 pin connector, the body one is to help with picking up any stray interference, all I can say is the cossie ones didn't.
Old Jul 6, 2009 | 03:02 PM
costina's Avatar
costina
Live long and prosper!!
Make sure u have no water in the pipe and you must not tee of this pipe for other vac sources
Paul
Old Jul 6, 2009 | 03:16 PM
muz's Avatar
muz
Wye Valley Hardcore
Paul
Trouble is I've only got one vacum take off I can use and thats the one on the front thats T'd off. Looks like I need to add another one then.
Old Jul 8, 2009 | 03:02 PM
costina's Avatar
costina
Looking at your pic muz i can possibly see 2 issues 1st being the vac take off (very near thottle body) and the air charge temp which could possibly being masked by the tube that its sat in
Also the map needs to have a short as poss bit of pipe on i'd drill and tap the underside of manifold plenum in the centre for this imo
Paul
Old Jul 8, 2009 | 06:08 PM
raggey's Avatar
raggey
Default which way up
thats interesting which way up should the map sensor be on 2wd cosworth.
I have a kit car and i put the map inside the car and not under the bonnet also its upside down i think [ pipe at bottom].
Paul.
Old Jul 8, 2009 | 09:09 PM
costina's Avatar
costina
Paul.
pipe at bottom which is correct
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
