ST170 timing belt replace
Old Jul 3, 2009 | 07:46 PM
airwave's Avatar
airwave
Totally addicted t boost
Default ST170 timing belt replace
I'm currently building an st170 engine with hayabusa tb's on it , just wondering if anyone can give me some advice on timing the inlet cam, should i have the variable clutch in the anti clockwise or clockwise position.
any help would be great cheers
Old Jul 4, 2009 | 07:03 AM
Just copy alignment from present position.
Old Jul 4, 2009 | 11:50 AM
airwave's Avatar
airwave
thanks but not much help as timing belt was already off the engine when i bought it
Old Jul 4, 2009 | 05:24 PM
I don't know which way these rotate, pm me on monday if I've not pm'd you as will find out, but you may need to jog my poor memory!!
Old Jul 6, 2009 | 08:34 PM
airwave's Avatar
airwave
crankshaft rotates clockwise looking at pulley and inlet cam clutch turns anti clockwise to its rest position, which would i think retard the timing, just need to no whether to time it with clutch advanced or retarded, i spoke to local ford dealer and they said i would need diffrent special tools to the standard zetec tools
thanks stu
Old Jul 7, 2009 | 10:58 PM
Rick's Avatar
Rick
the pulley should be fully retarded clockwise
Old Jul 11, 2009 | 08:45 PM
pdfbt40's Avatar
pdfbt40
And its timed there with exactly the same 5mm plate for both cams and M8 pin for the crankshaft, so don't bother getting any more advice from that Ford Dealer.
Very early ST170 engines did have a sloppy inlet cam timing slot, that had to be packed with feeler gauges. Covered in a TSB for the timing proceedure ammending the TIS.
Martin
Old Jul 16, 2009 | 06:31 PM
airwave's Avatar
airwave
right so if inlet clutch is retarded in the clockwise position then how do i hold it there to put the belt on as even with the plate in the end of the cam the clutch automatically tries to go anticlockwise
Old Jul 16, 2009 | 10:33 PM
pdfbt40's Avatar
pdfbt40
Just forget that the inlet cam pulley has a hydraulic actuator in it. Set up the crankshaft at TDC with the timing pin, and the cams with the 5mm plate. Nip up the cam pulley bolts, check the tensioner setting. Remove the pin and plate. Rotate the crank at least 2 turns clockwise and stop at #1 TDC (using the timing pin). Check the plate slides into the cams and the tensioner is still correct. Repeat as necessary. Tighten cam pulley bolts to correct torque.
In other words, exactly the same as a normal Zetec-E. As I said before the only difference is if it is an early 2002 engine, then follow the TSB in the TIS.
Martin
Old Jul 17, 2009 | 05:11 PM
airwave's Avatar
airwave
spot on mate thats what ive done just hope its ok , sorry if ive sounded stupid but im more used to a diesel engine this is all new, thanks for your help stu
Old Jul 17, 2009 | 09:13 PM
Very interesting.
Old Jul 18, 2009 | 01:03 AM
pdfbt40's Avatar
pdfbt40
No problem, everybody has to learn.
I've got an engine with an ST170 head with VVT deleted. Yet to findout if the static timing I've selected is near enough, let alone optimal. I blame the (ex)wife.
Martin
Old Jun 20, 2012 | 09:42 PM
scott-78's Avatar
scott-78
Default vvt cam timing
Hi... I am about to time up a Focus ST170 that currently has no belt on for reference. Just read these instructions and originally assumed you have to somehow pre-load the inlet cam, but it would appear that you dont?
If I time it the same as any zetec with my cam locking bar and tdc crank screw, will the vvt still work?
Old Jun 20, 2012 | 10:30 PM
pdfbt40's Avatar
pdfbt40
Yes, as I described in my 07/09 post.
The only other thing, if its an early one ~2002/3 build, is to also follow the TSB on this subject. Essentially the alignment slot on the inlet cam was too wide. So when the plate is inserted, feeler gauges are inserted in the front end of the slot to take all the clearance.
Martin
Old Jun 21, 2012 | 06:00 AM
scott-78's Avatar
scott-78
Brilliant.. not sure who started this 'pre-loading' myth but glad it isnt true.
Many thanks ... Feeler gauges on stand-by!
RUBY123
Oct 22, 2023 12:04 PM
cos elle
Sep 1, 2015 06:48 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
borboyous
Aug 22, 2015 11:17 AM
taylora1409
Aug 12, 2015 12:06 PM
