zetec turbo injectors
Old Jun 21, 2009 | 12:30 PM
fiestamk2's Avatar
fiestamk2
Default zetec turbo injectors
i have the 2litre side feed injectors in my fuel rail (std).whats the nxt upgrade from there with out going daft on the ccs
Old Jun 21, 2009 | 12:40 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
it depends on what power you are aiming for what fuel pressure you are running what manigment are you useing ect ect
Old Jun 21, 2009 | 12:45 PM
keyz's Avatar
keyz
Arse
pending on how much boost/ power your using with you fez u can use the Nissan 200SX (S14) injectors. The only thing you will need is the conector end from the nissan fuel wiring loom to conect onto the injectors as the ford ones dont fit! Also they are NOT compatable with the fords ECU. u wil need an aftermarket one which i would assume u have running a turbo!
with a comparrison to fords injectors..
Zetec injectors
Flow rate ~ 160-170 cc/min - Impedance - 16 Ohm
Nissan injectors - SR20DET - 2 000 cc, 200HP
Flow rate - 375 cc/min - Impedance - 10,7 Ohm
both injectors are side feed also. what ive heard is that you may need bigger o rings to stop the fuel seeping past.
there is a site somewhere out n about on tinernet that will give u alot more info, but i cant find it for the life of me but hope that helps anyhows :
Old Jun 21, 2009 | 01:13 PM
fiestamk2's Avatar
fiestamk2
what are the std 2litre zetec injectors rated to
Old Jun 21, 2009 | 04:46 PM
keyz's Avatar
keyz
Arse
155 bhp, then youll be pushing the ecu, injectors & the plastic manfold to the limits as it will crack under preasure.
Old Jun 22, 2009 | 05:04 PM
zvhrst's Avatar
zvhrst
best and esiest way is to grab a focus RS inlet and fuel rail,
the std injectors will be good enough for 360bhp with std fuel pressure
i have my old ones avaliable
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
