mfi xr3i fuel pump relay problem.help plz
Old Jun 15, 2009 | 08:13 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
Default mfi xr3i fuel pump relay problem.help plz
my stepdad has a white xr3i mfi.when he got it ,it had a problem,the fuel pump relay wasnt bridging across.if u open the relay up and push the solenoid thing cross the pump would work.
i took the relay out and by-passed it with a piece of wire so he could use it.ive since got a new relay that i know works.
i put it in and it bridges across when turned over but doesnt fire up the fuel pump?
anyone have any ideas why?
so ive put the piece of wire back in for now but not sure if that could cause any damage.
cheers.any help apreciated
Old Jun 15, 2009 | 09:27 PM
andyuk's Avatar
andyuk
Default relay
fuel cut off inthe boot??
Old Jun 16, 2009 | 06:30 AM
rickbartlett
G911 TTA
u only have them on efi xr3i mate,not mfi
Old Jun 16, 2009 | 08:40 AM
The piece of wire won't cause any damage.
As the relay is switching ie closing contacts when it should you know it has earth and switch feed, so long as the battery input 30 or 30/51 and the output 87(pump) are not broken it will work, assuming the relay is ok.
Are you sure when you bridge the relay holder you are not doing it between the switch input and 87 output ?
Old Jun 16, 2009 | 11:18 AM
rickbartlett
G911 TTA
im not sure wich one im bridgeing.but as soon as u turn igniton on the fuel pump primes??
Old Jun 16, 2009 | 08:00 PM
rickbartlett
G911 TTA
Old Jun 18, 2009 | 08:18 PM
rickbartlett
G911 TTA
up
Old Jul 1, 2012 | 05:59 PM
coolrunner6969's Avatar
coolrunner6969
i have a g reg xr3i the fuel pump is no good so i put in anew one the car wont start or the pump wont prime up i had a look at the cut off switch in the boot but it seems its not ther so wer is it and the relay thanks
Old Jul 1, 2012 | 06:31 PM
coolrunner6969
Angry ford escort xr3i
i have a g reg xr3i the fuel pump is no good so i put in a new one the car wont start or the pump wont prime up i had a look at the cut off switch in the boot but it seems its not there so were is it and the relay thanks
Old Jul 3, 2012 | 12:46 PM
martysmartie's Avatar
martysmartie
As said MFI don't have then but EFI do, due to the age yours could be either one, but not having a cut out suggests it may be MFI.
I don't know about the relay, perhaps behind the dash, if not in the fuse box?
MFI has a "Timed" relay which is purple and expensive to buy.
Martin
JK12
33
Apr 26, 2021 12:09 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
stevierob
Sep 7, 2015 07:09 PM
