Cossie wont run clean - two/three cylinders PLEASE HELP
Old Jun 12, 2009 | 09:00 PM
Kverna's Avatar
Kverna
Virgin-popper
Default Cossie wont run clean - two/three cylinders PLEASE HELP
Hi everyone.
A mate of mine is having some troubles with his cossie.
We have tried to changenot sure on all the technical names)
-Ignition module
-phasesensor
-cranksensor
-coil
-dissy
-plugs
-pluggleads
-blue sensor back of head
-changed ecu
-earth
-measured clearances on sensors etc.
Still runs like a scooby(or a cosworth with bent valves)
The only thing we havent changed is the map sensor, but doesn't change much when we unplug the vacuum, just revs higher.
Any ideas ? The car runs smooth when the temperature gets higher and he floors it. The plug on cyl 1 is soaking, the rest is normal.
Maybe injector ? We measured and every injector gets the same current, and he tested each one spraying out in the air, and looks like it's ok.
Vids:
Normal:
Now:
Old Jun 12, 2009 | 09:20 PM
Alvyn's Avatar
Alvyn
checked the inlet manifold gasket?
Old Jun 12, 2009 | 10:06 PM
Kverna's Avatar
Kverna
Virgin-popper
Nope. Will the car act like this if the seals broken ?
Old Jun 13, 2009 | 09:49 AM
In the second vid it clearly is just 1 cylinder, the same 1 all the time that is not pulling it's weight and missing.
I would try to identify that cylinder by pulling plug lead/s with it running, then try a new plug.
A plug that has ever ben soaked in fuel won't always work properly afterwards, but it's something individual to a cylinder so try plug and injector, even swapping injector over with another cylinder to make sure it is the injector and not the wiring to it, if the problem transfers then you know it's the injector.
Old Jun 13, 2009 | 10:27 AM
Kverna's Avatar
Kverna
Virgin-popper
Yes we tried to pull each plus lead, and at first it was number three. But now there's no change in the sound when we pull number 1 and 2. Tried to change plugs but still the same, I suggested to switch the injectors last night, so maybe thats the problem. Only number 1 gets wet with fuel
Thanks for the replys
Old Jun 15, 2009 | 09:31 PM
andyuk's Avatar
andyuk
Default cam
check you cam ent snapped as i had this problem
Old Jun 15, 2009 | 09:44 PM
costina's Avatar
costina
Live long and prosper!!
if its a 4x4 check engine multiplugs on bulkhead
or 2wd try another map sensor
Paul
Old Jun 22, 2009 | 07:56 AM
Alvyn's Avatar
Alvyn
any further news on the problem??
original
Apr 28, 2026 05:20 PM
ekjim
Aug 17, 2015 08:57 PM
Zoggon
Aug 10, 2015 10:39 AM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
