YB engine bearing replacement
Old Jun 7, 2009 | 07:09 PM
Stakis's Avatar
Stakis
Default YB engine bearing replacement
Who have done this, maybe can tell me if it's possible to change the bottom end bearrings without stripping the engine (which ones, or maybe all)? I mean from the bottom ( I remove sump and do everything from there). As I know nissan sr20det, etc. this can be done without problems. Thanks
Old Jun 7, 2009 | 07:18 PM
Don't see why not, so long as crank dropped a touch when unbolted, can't remember the thrust bearing fitment, the upper one if captive would be a problem, but so long as all can be rotated don't see why not, not the way I'd do it, if it needed new shells I'd strip and examine the rest.
Old Jun 7, 2009 | 07:19 PM
Toe Knee's Avatar
Toe Knee
Yes mate its no different to any other engine all the bolts you need to undo are underneath so sump off and away you go, makes it alot easier if the engine is out thou!!! The other thing is why are you changing them?! as if changing them is it not worth doing the piston rings too?!
Old Jun 7, 2009 | 07:22 PM
Stakis's Avatar
Stakis
they don't need to be replaced (I believe) but the engine now has 60.000miles on it, so I am affraid, that the bearings can have wear marks... So better to replace with new, quality ones? Because if they will fail, I will have to ground crank, use oversized repair bearrings, etc.
Thanks for advices :S I really just planning to touch the isnide of my engine.
Old Jun 7, 2009 | 07:30 PM
Stakis's Avatar
Stakis
also, the oil pump also can be replaced with the sump removed??
Old Jun 8, 2009 | 05:37 AM
grcossie's Avatar
grcossie
Yes it can
j.hammond1
30
Oct 31, 2021 05:28 PM
malkiemac3579
Jul 14, 2017 12:10 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Blown Hell
Aug 5, 2015 07:22 AM
muz
Aug 1, 2015 06:48 AM
