1800 zetec conversion
Old Jun 3, 2009 | 10:32 PM
duncansharp76's Avatar
duncansharp76
Default 1800 zetec conversion
hi all i have a mk4 escort van with a S2 rst engine. I am wanting to replace it with a 1800 efi zetec. I have a zetec from a R reg mondeo along with the loom and ecu. Is there anything else i need for said conversion eg driveshafts, gearbox etc etc. WIll welcome any advice and input
regards
duncan
Old Jun 3, 2009 | 10:49 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
tht a silver top lump bud?only things ya gonna have problems with is the PATS
check here my guide i done a while ago, been helpful to a few peeps
https://passionford.com/forum/pictur...uid-guide.html
Old Jun 4, 2009 | 05:26 PM
duncansharp76
thanks dude. what aboutgearbox and driveshafts etc etc???? i have a escort diesel gearbox on my escort, will the zetec bolt upto it or do i need to change or modify the flyweel etc etc
thanks for any help
Old Jun 4, 2009 | 05:47 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
thanks for any help
stick with the gearbox + driveshafs your van has the standard clutch from your s2 engine or 1.8 zetec will be fine same said for the 1.8 flywheel
Old Jun 4, 2009 | 07:30 PM
duncansharp76
sweet cheers for that dude
Old Jun 7, 2009 | 03:25 PM
fonfe123's Avatar
fonfe123
engine will not fit straight in due to it being from a mondy. same things need to be changed as if you were fitting a 2l into the car, most people use a 1.8 from a fiesta or another escort due to this. is all easily done but need to source sump, water pump, oil pump oil pick up pipe n a few other bits for it all first. a compleate guide for this including doing the engine mount, list of parts etc is all in the engine section of the
s2rs.co.uk site + a list of 1.8 non pats ecus and the wiring info you will need
Old Jun 7, 2009 | 09:26 PM
duncansharp76
fonfe i couldn see a engine section on your site or am i going blind???
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
