Help Needed Please!
Old May 23, 2009 | 10:05 PM
cos84's Avatar
cos84
Default Help Needed Please!
I recently converted my 2wd sierra to stage 3. Since then it will not idle correctly, it is hunting. Also it seems to be running very rich, but this was a problem before stage 3 conversion.
Suggestions Please!
Thanks in advance
Andy
Old May 24, 2009 | 06:43 AM
So it was running rich/badly before the mod to stg3.
I would be tempted to change the CTS, then set CO to what chip maker says, then adjust base idle, check your fuel pressure is as needs to be for chip.
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
