rs turbo
Old May 20, 2009 | 05:00 PM
andrew ginnever's Avatar
andrew ginnever
Default rs turbo
anybody help when i try overtaking got no power mostly does it going up hill
Old May 20, 2009 | 08:23 PM
Slik Johnson's Avatar
Slik Johnson
Silly question but when was it last serviced?
Old May 20, 2009 | 08:25 PM
xr3irally's Avatar
xr3irally
clutch ok? do the revs rise and the car doesn't go anywhere?
Old May 21, 2009 | 12:03 PM
andrew ginnever
Default reply
it was serviced in jan
Old May 21, 2009 | 12:05 PM
andrew ginnever
no it doesn't go anywere plus the biting point is on floor but it's been like that for about 2 years don't want to put a new clutch on it if it's not the clutch
Old May 22, 2009 | 10:36 PM
Big-Dan's Avatar
Big-Dan
Fuelling issue maybe?
Old May 22, 2009 | 10:47 PM
Slik Johnson
Yer to me it sound like the moment you try to force more fuel through it struggles, so I would start by looking at your fuel. Start at your tank to filter, the lines for kinks all the way through to your injectors. From front to back. Then you can rule out fueling. Let me know how you get on.
One thing I learned was Haynes manuals are a bible and can help alot more than you think. If you havn't already got one I would say invest in one
Old May 24, 2009 | 06:53 AM
When was the fuel filter last changed ?
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
