Fuse box on ERST
Old May 19, 2009 | 06:00 PM
white2lsr's Avatar
white2lsr
Default Fuse box on ERST
Can soomeone give me a rough guide as to how you remove the fuse box from the bulk head on and ERST please. Im planning on fitting a repair panel so need it removed.
Thanks for any help.
Old May 19, 2009 | 06:03 PM
JesseT's Avatar
JesseT
Lift the electrical internals out of the casing and you will find two or three screws. Then disconnect every loom connector from inside (not fun, I know) and pull the loom out to the engine bay side.
Old May 19, 2009 | 06:05 PM
white2lsr's Avatar
white2lsr
so i need the dash out then.
Old May 19, 2009 | 06:20 PM
Jimmyc's Avatar
Jimmyc
I wouldn't weld it with the dash in bud, if the heat gets through to the sound deadening behind it might not be too fun.
As said, just 3 screws to unscrew the fuse box then pull loom into engine bay cut out rust and weld new panel in
Old May 19, 2009 | 06:30 PM
white2lsr's Avatar
white2lsr
How easy are the dash boards to take out?
Old May 19, 2009 | 06:34 PM
Jimmyc's Avatar
Jimmyc
Not too bad, take a look, theres about 8-10 bolts around the main dash, then the centre console bolts.
The loom might be a bit of a PITA though.
If you're not sure pick up a haynes manual, got all the bolts you need to remove on there i'd imagine, also useful to have about for torque settings etc.
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
