Battery Light....
Old May 18, 2009 | 11:39 PM
Denzil's Avatar
Denzil
Default Battery Light....
hi need some help was in KFC drive in and then why i was waiting buy Battery light just came on so i went home and checked the belt and stuff all seems to be fine the car starts stilll wat could this be any ideas please neeed for work
Old May 18, 2009 | 11:42 PM
Chopshop85's Avatar
Chopshop85
what car is it?
Old May 18, 2009 | 11:43 PM
Denzil's Avatar
Denzil
Escort Rs 2000 mk5
Old May 18, 2009 | 11:46 PM
Chopshop85's Avatar
Chopshop85
hmm could be an alternator fault? getting tired perhaps, im not to hot on newer escorts lol
Old May 19, 2009 | 12:27 AM
BigErn's Avatar
BigErn
check the voltage when its running. Sounds like alternator has packed up.
Old May 19, 2009 | 05:14 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
Mmm KFC.............
Old May 19, 2009 | 12:32 PM
Denzil's Avatar
Denzil
BUMP BUMP Just bin to me car started the car battery came on for couple of seconds then went of but if i turn lights on or stero it lights up agin any ideas could it be altnater sending bad voltage thanx
Old May 19, 2009 | 12:43 PM
martysmartie's Avatar
martysmartie
More likely to be faulty regulator.
Martin
Old May 19, 2009 | 02:51 PM
Alvyn's Avatar
Alvyn
check the thin blue wire on the back of alternator hasn't broken off!
Old May 19, 2009 | 03:39 PM
martysmartie
If that happened it would have no battery light at all.
Martin
Old May 19, 2009 | 04:24 PM
Most likely a loose diode connection, I'd get a recon/rebuild as ap, it could be ok for years, could go next week, I always do things at the most convenient time, saves getting a ear bashing from other half if it goes when out shopping.
Whilst light is on though just check to see if still charging ok, as it is possible, if still charging ok up to you what to do.
Old May 19, 2009 | 07:31 PM
cabriolet's Avatar
cabriolet
tab is right alternator knackered change it before it lets u down yes i would know am a reconditioner
Old May 19, 2009 | 08:48 PM
Phil2002's Avatar
Phil2002
agree with tabs and cabriolet get a new alterenator on it.
cheers,
Phil
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
