3 door cos accelerator cable ??
Old May 18, 2009 | 09:27 PM
D8VYE's Avatar
D8VYE
Default 3 door cos accelerator cable ??
Hi, d reg 3 door cos acc cable,just got in pedal feels real gritty ,getting stiffer,want to buy a cable tommorow,does anyone know what models the same cable was fitted to????,just seen one on ebay,60 quid plus 8 quid post !!!,at least if i go knowing what other models to check for should make it easier to get sorted...cheers dave...
Old May 19, 2009 | 04:31 PM
Check with ford to see if same part number listed for others, very common end fittings, possibly efi pinto engine sierra ?
Old May 19, 2009 | 05:56 PM
nicksaph's Avatar
nicksaph
just bought one for my 4wd from ford still available and cost me Ł40 not sure if they are the same as the 3dr but it is possable
Old May 20, 2009 | 05:18 PM
costina's Avatar
costina
Live long and prosper!!
IT WILL NOT BE THE CABLE !!! check the linkage were the arc is on throttle body that will be dry and needs some grease
Paul
Old May 20, 2009 | 06:17 PM
Interesting you should say that Costina, my tb had a hole drilled slightly on the wonk that goes through the centre of the linkag/arm and acts as a pivot, this caused severe binding on mine, just machined the bolt stem down a bit.
Old May 20, 2009 | 06:30 PM
costina's Avatar
costina
I had the same on mine where the linkage was dry i even changed the pedal like a plank and then it clicked lol
paul
`spotty
Sep 25, 2015 11:41 PM
landaqmabba
Sep 15, 2015 07:16 PM
gcfcos
88
Sep 15, 2015 03:48 PM
Bransby
Sep 14, 2015 08:54 PM
Marino
Sep 12, 2015 11:10 AM
