2wd idle problem
Old May 17, 2009 | 10:51 AM
Phil2002's Avatar
Phil2002
Default 2wd idle problem
I've just bought a 2wd saff cossie and has one small issue when i start it it will idle perfectly no missing or hunting at all but when i pull away and come to a stop or push the clutch down the revs drop really low(some times cuts out) and then rev up and settle and it will then idle again perfectly until i pull away and come to a stop again.
is this an air leak problem or should i clean out the iscv??
any pointers would be great.
cheers,
Phil
Old May 17, 2009 | 11:00 AM
Check your CO, sounds as though it may be a bit lean, the fact that the idle speed changes says the valve is working ok, also may want to check your base idle when hot.
Old May 17, 2009 | 11:13 AM
Phil2002's Avatar
Phil2002
brilliant thanks for that the guy i bought it off did mention the base idle. how do i adjust the base idle??
cheers,
Phil
Old May 17, 2009 | 12:41 PM
Phil2002's Avatar
Phil2002
cheers,
Phil
no need to reply just found a thread that answered my question.
should have done a search in the first place instead of being lazy.
cheers,
Phil
Old May 17, 2009 | 03:24 PM
Just post up if anymore trouble.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
RSBryden
Sep 6, 2015 08:39 PM
FlashRS
13
Aug 31, 2015 06:02 PM
