removing TCA bushes advice
Old May 17, 2009 | 01:40 PM
R5COS's Avatar
R5COS
Default removing TCA bushes advice
Hi guys, i have to remove the inner and outer bushes from my front track control arms for escos, they are new arms from ford so the rubber bushes are in very tight whats the best way to remove these without damaging the bushes, i dont want to butcher them out but poly bushes will be going back in so i will hack them out if i have to.
Old May 17, 2009 | 03:22 PM
Get a socket that is larger than the outside of the bushes, and one around the same size eas the metal sleeve in the centre of the bushes, put in a vice so the thinner socket presses on the sleeve and so pushes the bush out into the larger socket as you tighten the vice squeezing it all together, does come out easy and does not damage the oe bush, apart from a few scuff marks.
Old May 17, 2009 | 03:48 PM
R5COS's Avatar
R5COS
thanks mate the outer bush wont push through dough will it isnt it in 2 bits, should i tap these out ??
Old May 17, 2009 | 04:15 PM
The outer one where the arb goes through, is just a case of levering them a bit, to push through hole if single piece, or if two piece just prise up the outer cup to remove.
rex647
Mar 6, 2022 06:20 AM
yatta
May 21, 2016 10:31 PM
Marino
Sep 12, 2015 11:10 AM
hopper350
Sep 4, 2015 12:53 AM
