Endura DE engine swap
Old May 13, 2009 | 07:20 PM
Skivey's Avatar
Skivey
Default Endura DE engine swap
Hi there, quick introduction, im Matt from Wells, Somerset.
I just replaced my 1.8 TDi 1992 Engine with a Endura DE 1999 engine, I was told this is perfectly alright...
When I went to change it, i noticed there were some slight differences, mechanically. I changed the parts which needed changing (exhaust end etc) but now Ive come to the wiring, its slightly different. I know that, I could do it quite easily if I tried but the wire colours are different and I cant help but think If i got some wrong, itll blow something and ill have to get another engine.
The reason for change was no other reason than my TDi ended its life oiless and dead on the M5 on the way back from the dodgy garage I had cheaply bought it from.
The car is rust free and in perfectly good nic and not worthy of scrapping.
ANY help would be greatly appreciated.
Matt
Old May 14, 2009 | 03:36 AM
Emmanuel's Avatar
Emmanuel
Go to a scrappy and get a head and put it on the td. you'll need to change fuel pump, compression ratio on the n/a block so just re do the head.
jcth1 2008 Peugeot 307 CC: 2.0HDi (Car i let the gf drive and will modify after 3 years)
1994 Citroen AX: 1.5D (runaround and now deceased grandfathers last car)
1992 Citroen AX: 1.4 GTi
1992 Citreon AX: 1.4 GT (Going to become a derv)
__________________________________________________ _______________
clawfoot tub
Fixed Rate Self Certification Mortgage
Old May 18, 2009 | 07:29 PM
forevaford's Avatar
forevaford
na mate,
i take it its just the pump wiring different?
right.... if so you can either swap the gubbins and sensors from the original car pump to the new pump, note these are enclosed im metal armored casings with shere bolts but can be done,
or pehapps easier to just swap the pumps.
JoeyBoyden
Jan 4, 2024 02:36 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bobby9779
Aug 11, 2015 06:47 PM
vdubo7
Aug 2, 2015 08:17 PM
