Urgent help/advice needed cos engine trouble
Old Feb 26, 2004 | 04:50 AM
Default Urgent help/advice needed cos engine trouble
Went to my car last night and noticed a puddle of oil under the car,
opened the bonnet and there was oil all down the o/s inner wing and
the sump gaurd was covered,got a torch to see where it it was leaking from and noticed that the breather pipe that fits onto the airbox was off.
checked the oil level before starting it and it was just above min so topped it up then fired it up.looked back under the bonnet and there was oil spitting out of the breather pipe and that was only on tickover i did'nt try any revs i just turned it straight off.
car is a 91 4x4 saff running stg3.
Roy.
Old Feb 26, 2004 | 06:57 AM
alan rainbow's Avatar
alan rainbow
sounds like rings but check the breather system first
Old Feb 26, 2004 | 10:30 AM
Fozy's Avatar
Fozy
it could be that the breather was blocked. as you've started or if you drove it the nite before, the crank case pressure could have been so much that it clear the system but its just caked in oil now, Had the same problem on mine. Had oil coming out for a while until i took the breather off and cleaned all out. Never done it since.
Old Feb 26, 2004 | 11:03 AM
Milko's Avatar
Milko
I would get GpA breather m8, standard setup cant cope with the presure Stage 3 creates.
Old Feb 26, 2004 | 02:32 PM
I have heard that the standard breather wont take the pressure of high boost but for it to spit out oil on tickover when there is no boost running through the engine is what's worrying me,if you put your hand over the top of the breather pipe (air box end) it will soak your hand in oil,it's spitting the oil out out at quite a rate.
Roy.
Old Feb 26, 2004 | 04:47 PM
Went back to the car to have another look in daylight and rather that spitting the oil out the breather pipe it's gulping it out,again i did'nt rev it to see if it got worse it was just on tickover.
The engine itself sounds normal,there's no misfire or running lumpy!
Old Feb 26, 2004 | 07:57 PM
I can only think its a breather pipe full of oil creating constant suction from your sump? clean your breather, shitty job in an awkward place too.
Old Feb 29, 2004 | 12:03 PM
Have took the little plastic breather apart to clean it and want to take out
the oil seperator but it wont budge,is it bolted on to anything or is it just held
in place by the pipe that goes onto the sump?
Old Feb 29, 2004 | 12:39 PM
Tony Ryan's Avatar
Tony Ryan
How old is the turbo on it , is it in good nick ?? It may be its failed and is pressurizing the crankcase pumping fumes out of the easiest place, i.e the breather !
Old Feb 29, 2004 | 12:48 PM
The turbo has done about 60000 miles but seems ok,theres slight up and down movement on the shaft but it boost's ok n dont smoke.
JoeyBoyden
Jan 4, 2024 02:36 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
col93saphcos
Aug 7, 2015 03:21 PM
