Focus electric window problem
Old Apr 7, 2009 | 01:27 AM
RUSSELLB1904's Avatar
RUSSELLB1904
Too many projects........
Default Focus electric window problem
How can i check the electrics for a drivers side window? I think the switch is knackered as it only works the p/s window, but how can i check the electrics for the drivers side window before buying a new switch unit???
Old Apr 7, 2009 | 03:43 AM
lurch1977's Avatar
lurch1977
If you have a battery, take the door trim off find where the switch plugs into the motor and give it a positive and negative connection. I think there are 3 wires one neg and one pos for up and one for down
Old Apr 7, 2009 | 05:28 AM
GVK.'s Avatar
GVK.
If you have the interior light on, and press the electric window switch - does the light dim?
If it does, the switch is working. If it is (switch working), it's usually the motor.
Old Apr 7, 2009 | 08:16 AM
JonathanJ's Avatar
JonathanJ
Another way is to listen very carefully to the switch as we have had loads of them go , see if you can hear it "click" as the microswitch works , but we have also had the window regs go aswell , easy way is pull the switch out and get multimeter accross connections and see if you get continuity , can sort you a diagram out if you like , but sure it will be on here somewhere , then if switch is ok check regulator by bridging straight over the wiring block , at least that way you do not need to take door trim off .
Old Apr 7, 2009 | 12:02 PM
RUSSELLB1904
The switch clicks, tried a spare one from the scrappy and even that did the same. Its sounding like the motor or regulator from whats said on here but i'll check them out as got a spare battery multimeter.
But if anyone has a diagram to show me which wires to check for continuity or whatever it is that would be great as i don't have a clue with electrics only mechanical stuff.
Old Apr 7, 2009 | 03:52 PM
pdfbt40's Avatar
pdfbt40
I'm assuming its a 3 door...
You know the switch is getting a 12v feed as the passenger window is working, so its just checking if 12v is going to the regulator or not.
Martin
Old Apr 7, 2009 | 04:47 PM
RUSSELLB1904
Well the light flickers so its sounding like the regulator/motor.
Forgot to say its a five door with just front electric windows.
Old Apr 9, 2009 | 06:29 PM
JoeSmith's Avatar
JoeSmith
Ive got a front electric window motor for sale if your interested
Old Apr 9, 2009 | 09:06 PM
Its a common fault on the focus,s for the motors to pack in.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
