Sierra module???????
Old Apr 5, 2009 | 02:43 PM
stevedohc16v's Avatar
stevedohc16v
Default Sierra module???????
Does anybody know where the module is that controls the low fuel and washer fluid lights on a sapphire cosworth? the wiring diagrams do show one between the switches and the warning lights.
Steve
Old Apr 6, 2009 | 12:47 PM
martysmartie's Avatar
martysmartie
Steve
Would imagine it would be the AWS module (Not the bulb failure module)
Martin
Old Apr 6, 2009 | 02:14 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Martin
Yup, also controls the door ajar and ice warning display. Lives on the passenger side footwell behind the lower dash.
Old Apr 7, 2009 | 12:07 PM
stevedohc16v
Cheers fellas
Steve
Old Apr 7, 2009 | 03:09 PM
jon@work's Avatar
jon@work
I thought that the low fuel and low washer fluid lights were simply switched by the relevant sender, either in the fuel tank or washer bottle, and that there isn't a "control module" required for them
Old Apr 7, 2009 | 04:23 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Disconnect yours and see if the fuel light comes on
The old Mk1 Ghias had a similar, but more comprehensive display that was all controlled by the same module - oil level, coolant level, brake level, as well as fuel and washer level. The Mk2 Sierra's one is very much cut down.
Old Apr 7, 2009 | 07:35 PM
nicksaph's Avatar
nicksaph
there is also a module behind the cubby hole on the passengers side dash
https://passionford.com/forum/ford-sierra-sapphire-rs500-cosworth/288622-module-location-for-dash-board-warning-indicator.html
cheeRS nick
Old Apr 9, 2009 | 09:19 PM
If you take to panel out above the glove box there is the control unit which is for the warning display.Im sure it doesnt do the fuel light and washer jet low lights.
Old Apr 10, 2009 | 11:04 AM
nicksaph's Avatar
nicksaph
click the link on my last post mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
