Module location for dash board warning indicator
Someone has kindly given me a replacement module/brain box for the warning indicator on the dash, you know the one with the little birds eye view of the car and tells you if the doors are open etc etc
does anyone know its exact location under the dash before I start stripping the dash down? my car is a 1990 4x4
Any help is much appreciated
Luciano
Luciano
Left hand kick panel off and its just above there on a 2wd and most other sierra's can only assume its the same on a 4x4. Which lights are constantly showing as being out on your one?
All totally wrong!
Its behind the cubby hole above the glovebox on a 4x4 sapphire, where the ECU would sit on a 2wd. Squeeze the middle of the cubby together and pull it out. You'll see the unit at the rear left.
Are your cars 4x4? The thing under the dash in the driver footwell is something to do with the central locking/alarm/immobilser.
The 1990 sapph 4x4 i worked on had it behind the dash cubby
My 1991 sapph 4x4 has it behind the dash cubby
My friends 1992 sapph 4x4 has it behind the dash cubby
Luciano
Luciano
Behind the cubby as i said.
The ECU in the drivers footwell says 'ford security' or something on it and is to do with the security lol. It does not have anything whatsoever to do with the dash warning display.
Well if i unplug that ecu behind my dash the warning light display doesn't work?
The one above my accel pedal was deffo something to do with the security features on the car....
Not sure its in the garage and there's two cars parked in front of the doors, I'll have a check tomorrow, don't wanna be doing the valet duty tonight
Will just have to work out which one I have, fella who gave it to me said it was above the acc pedal, but it does look like the one in your pic on the ecu side
Luciano
Luciano
The one you are talking about under dash, near the pedals, simply does the bulb blown warnings - ie headlight, brake light out.
The one i've shown behing the cubby, does the rest of the features and supplies power to the warning display.
So to sum up
Supplies power, does door open, low temp etc etc
This one is simply the bulb out ecu, the display works without it plugged in, but doesn't give you any bulb tests. I thought it was a security one, but the plastic security relay is just attached to the metal bulb warning one.
So to sum up
Pink sticker above accel pedal
If your display isn't working at all, its the white sticker one you need. Failure of the pink one just means the wee bulb symbols don't show on the display, but the door open and frost symbols still show.
i have been trying to fine a problem with my G, W, M, for absolute yonks. some times it works and somtimes it don't tryed three diffrent control boxes above the pedal and tried tracing the wire under the dash using a wiring diagram, still no joy.
and after reading this post i had a look behind the cubby hole and as if by magic i find another control box that is not plugged in correctly
That's what its all about bruv sharing of knowledge/information
Luciano
Hi guyss..
Can anyone , send me a wiring diagram of the Sierra Sapp Cosworth `Lamp Failure Indicator - Pink Sticker`
Cause i have the Lamp Failure, with plug & with 15cm wire `Long/Cut Off`
I want to make the warning light (center dash) Work On !
Any help... ? Many Thanks.. Mates
Steve Escos
01-10-2015 06:57 AM
