brake pressure problem on mk3 escort
Old Mar 31, 2009 | 07:11 AM
smithy rs2k's Avatar
smithy rs2k
Default brake pressure problem on mk3 escort
im doing a resto on my y reg mk3 escort ive just renewed all the brake pipes,put a 2wd cosworth rear disc conversion and 4x4 cosworth front brakes on, they all seem to bleed up fine with no air but there is no pressure in the pedal it just drops to the floor,it did used to have brakes before it was parked up over a year or so ago,any ideas wot it could be??
cheers
Old Mar 31, 2009 | 09:41 AM
jon@work's Avatar
jon@work
unbolt the rear calipers when you are bleeding them - the bleed nipples, when the calipers are bolted in place, will not be the highest point of the caliper, meaning that not all of the air will had been removed
Vincereese
Jun 1, 2023 09:14 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
