weird noise focus st
Old Mar 28, 2009 | 03:07 PM
stuartrst's Avatar
stuartrst
Default weird noise focus st
hi can anyone help i have a 52 plate focus st yesterday whilst driving funny grinding noise from under the bonnet after closer inspection it is a metal box with one block of wires coming out of it it is bolted onto the bulk head right behing the inlet manifold i disconnect it the noise stop straight away car still ran ok does anyone no what its called thanks in advance.
stuart
Old Mar 28, 2009 | 03:11 PM
n13los's Avatar
n13los
a.b.s unit maybe? any brake pipes coming from it?
Old Mar 28, 2009 | 03:13 PM
stuartrst's Avatar
stuartrst
no brake pipes just one plug with about five wires on it it is quite high up on the bulk head
Old Mar 28, 2009 | 03:16 PM
n13los's Avatar
n13los
get a pic up mate, someone should be able to identify it.
Old Mar 28, 2009 | 07:14 PM
stuartrst's Avatar
stuartrst
Old Mar 28, 2009 | 07:43 PM
JonathanJ's Avatar
JonathanJ
Is there a cable running out of it too the variable length manifold runner ?
Old Mar 29, 2009 | 10:17 AM
RichieST's Avatar
RichieST
Its the IMRC control box. There is a cable coming out of it that connects to the inlet manifold under the throttle body. What happens is that there is a plastic lever on the inlet that the cable attaches to. Part of the lever breaks off causing the cable to retract too far, thus stripping the gears inside that box. Have a look under the throttle body, you will see a cable flapping in the breeze that should be connected.
Ford have released an uprated plastic lever that is stronger than previous versions as it is a known fault.
You will need a new IMRC box and what is called a DSI clip!
Rich
Old Mar 29, 2009 | 10:44 AM
stuartrst's Avatar
stuartrst
Thank you i will know source one.
Botts
Sep 22, 2015 02:04 PM
Fudgey
Sep 17, 2015 01:06 PM
talon1
Sep 15, 2015 10:27 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
rsturbo27
Sep 5, 2015 05:08 PM
