Escos running probs small turbo
Old Mar 27, 2009 | 05:45 PM
cossynath's Avatar
cossynath
The Daddy
Default Escos running probs small turbo
Just fired my car up today after having the head overhauled fired up ok after a few turns but got a miss fire! its missing on 1 and 3 even tho there is a spark there on both these cylinders strange one this can someone help please? asap Thanks
07590648910
Old Mar 27, 2009 | 06:44 PM
JonathanJ's Avatar
JonathanJ
First thing to do I would say is check the basics , chech that the injector looms is on correctly on those 2 cylinders , check that the connectors are not opened up in the plugs , also just wip plugs out and check if they have a gap or are wet after attempting to run it , if they are wet then fuel is getting there , then you might be looking at maybe a sticky valve on each cylinder ...... trouble with these long distant diagnoses is when you are looking at it you check things automatically and try and make sense of what you see / hear / smell , just my 2 pence worth
BTW like the car , just looked at the other thread
Old Mar 28, 2009 | 11:02 PM
cossynath's Avatar
cossynath
The Daddy
Sorted now thanks to johnathanj knows his stuff thanks mate!
3i Jim
Nov 20, 2015 05:12 AM
Chas
Sep 21, 2015 08:57 PM
james kiely
Aug 28, 2015 08:58 PM
IAN RS2k
Aug 18, 2015 07:51 PM
ray barker
Aug 7, 2015 09:00 AM
