S2 not starting help please!
Old Feb 23, 2004 | 12:38 PM
Default S2 not starting help please!
Im after some help on my S2 2.1 zvh. When i take it on a run and turn it off the engine doesn`t crank over properly. It is very slow to turn over and will not start up. If i leave it 10 minutes it then starts up. I have checked the starter motor and i have got 12v on the big connection when the ignition is on which drops to 8v when its cranking. The small conector has 4v when cranking. Would it be with the new larger engine that i might need a bigger starter and battery? Or could it also be that it is overheating because i haven`t got a heat shield fitted.
Thanks for any advice.
Barney
Old Feb 23, 2004 | 07:13 PM
HI,
COMMON FAULT WITHOUT HEARSHIELD,
Dave,
Old Mar 8, 2004 | 08:40 AM
Fitted new heat shield and new battery still no better
Any help please
Barney
Old Mar 8, 2004 | 01:15 PM
How old is the starter motor? It could be on it's last legs or full of clutch dust.
Old Mar 8, 2004 | 01:41 PM
sounds like lazy starter motor from using without heat shield, or just old age,
Dave,
Old Mar 8, 2004 | 01:51 PM
CabrioTurbo's Avatar
CabrioTurbo
Yep cooked or generally buggered starter. just replace it along with a heat shield, although it shouldnt be that necessary on a zvh as the starter is at the back isnt it?
Old Mar 9, 2004 | 04:11 PM
Sorry i took a while to reply!No the starter is at the front and i`ve just changed it for another secondhand one do you think it would be worth buying a new one?
Cheers Barney
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
