cvh to zetec conversion advice wanted???!!!!
Old Mar 8, 2009 | 12:40 PM
alun2's Avatar
alun2
Default cvh to zetec conversion advice wanted???!!!!
hi,im replacing the cvh with a 2.0 zetec and running it on twin 40s webber.
i dont know what i do with the wiring though,im not the best when it comes to this field!!
what do i need to do or buy to get the engine to have a spark????i have a low budget though!
cheers for any help
Old Mar 8, 2009 | 12:51 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Just run all the original zetec ecu+loom..
Old Mar 8, 2009 | 12:54 PM
alun2's Avatar
alun2
will it not read a fault on the ecu without all the connectors and fuel injection rail connected?
Old Mar 8, 2009 | 01:05 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The only thing that wouldn't be connected would be the injectors and MAF.. technically the ECU will be running on a base map (due to the MAF being unplugged), but it'd be more than adequate for simple spark control.
Any early 92-93 ECU & loom from any zetec-engineered car would be ideal..
Old Mar 8, 2009 | 01:07 PM
alun2's Avatar
alun2
cheers for that,so i just replace the loom complete in the car and do away with the old one?
Old Mar 8, 2009 | 01:09 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Well no, you're gonna have to make them work together.. The zetec loom won't need much more than power from your original loom.. and the tacho output.. and fuel pump perhaps..
Old Mar 8, 2009 | 01:10 PM
alun2's Avatar
alun2
right,ill probably be back on here for advice pretty soon wen i cant get it to run!!
Old Mar 8, 2009 | 02:30 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
your better off using mk5 CVH stuff as it runs carb and coil pack,no ECU stuff to mess with
Old Mar 8, 2009 | 02:38 PM
alun2's Avatar
alun2
how do i do that then,does it all plug straight onto a zetec engine?still good to use the 40s?
Old Mar 8, 2009 | 02:44 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
if you get an esc modual from an early fiesta (mk3 1.1 for example as long as its got a coil pack not a dissy) ) this will use the standard crank trigger from the zetec and a vacume line plumed into the inlet for the advance and they are realy easy to wire up
Old Mar 8, 2009 | 07:36 PM
Dan1281's Avatar
Dan1281
i'm pretty sure you can run the ignition system of a like 89-92 hcs fiesta/escort, they have the vac pipe on the edis
Old Mar 8, 2009 | 07:40 PM
orion_crazy_carl
orion=mini saff
the 1.3 stuff dont rev properly ive been told
Old Mar 8, 2009 | 08:16 PM
alun2's Avatar
alun2
would it just be easier to get an 1.8 zetec from the mk5 xr3i and run it on that loom with the twin 40s?
Old Mar 8, 2009 | 08:17 PM
orion_crazy_carl
orion=mini saff
if u can find it!but it is easier just to use the mk5 carb stuff,neater to
Old Mar 8, 2009 | 08:20 PM
alun2's Avatar
alun2
how do you mean the mk5 carb stuff?is the zr3i mk5 not on a carb?ive never had one i only ever kept myself to the mfi xr3i?is it just a stamdard mk5 escort 1.8 or is it a smaller engine?
Old Mar 8, 2009 | 08:28 PM
orion_crazy_carl
orion=mini saff
they done a 1.4CVH mk5 escort with a carb,well,single point injection, but it runs a coil pack,the looms really basic and easy to wire in
Old Mar 8, 2009 | 08:34 PM
alun2's Avatar
alun2
oh right,so i just dont connect the single point injection....well therell be nowhere to connect it anyway,it wont run badly or nothing without all plugs connected then?cheers for all your help!!
Old Mar 8, 2009 | 09:19 PM
orion_crazy_carl
orion=mini saff
the banger boys use it and they run and rev sweet,hence why i know the 1.3 stuff dont rev right!
Old Mar 8, 2009 | 09:27 PM
clarke5700's Avatar
clarke5700
its not edis it esc to compleatly different systems
Old Mar 8, 2009 | 09:28 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's ESC-I, the predecessor to ESC-II on the escort rs turbo!
moesin2005
Jan 23, 2022 06:28 PM
jaysoc1
Aug 20, 2015 08:18 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
adriansaleem
Aug 3, 2015 11:21 AM
