car revs at 2000rpm when started from cold
Old Nov 29, 2004 | 05:41 PM
stusfesta's Avatar
stusfesta
Default car revs at 2000rpm when started from cold
hi i have an escort van 1.8zetec and it revs really high when its started from cold, will never do it when the engine is warm and if i dont wait for the revs to drop before driving away, the revs just stay up
confusing!
Old Dec 1, 2004 | 04:59 PM
stusfesta's Avatar
stusfesta
bump!
Old Dec 3, 2004 | 08:16 PM
tonyturbo's Avatar
tonyturbo
iv just finished a 1.8 zetec turbo engine and it does the same. gonna change idle control valve just to eliminate it. i'll let u know the outcome..
Old Dec 3, 2004 | 10:47 PM
steviep's Avatar
steviep
air bypass/idle speed control valve whatever you want to call it. Had it loads of times.
Old Dec 4, 2004 | 03:47 PM
stusfesta's Avatar
stusfesta
where abouts is the idle control? thanks
Old Dec 4, 2004 | 08:01 PM
turbomondy's Avatar
turbomondy
all zetecs have a idle speed control valve which raises the revs when cold. it should go down on its own when the engine is warm dont worry. if you find it doesnt settle down when warm try reving the engine to about 5-6000 rpm quickly and that should reset it. let me know how u get on.
Old Dec 6, 2004 | 04:48 PM
stusfesta's Avatar
stusfesta
ok thanks mate, its just a bit annoying that i cant drive it till it drops otherwise when i stop at the end of the road its still revving at over 2000rpm, do you not think the idle control maybe worn out or dirty?
Old Dec 6, 2004 | 06:17 PM
turbomondy's Avatar
turbomondy
could be but its upto you if you replace it. you will find it on the back of your inlet manifold somewhere as it depends on what type of manifold you have but its roughly in the same place .
Old Dec 7, 2004 | 05:02 PM
stusfesta's Avatar
stusfesta
ok thanks mate, i think it is thta as it sometimes stalls when i come to a stop and doesnt idle very well now either, any ideas how much they cost?
Old Dec 7, 2004 | 06:02 PM
turbomondy's Avatar
turbomondy
try cleaning it out with carb cleaner as that sometimes does the job but if not you can get one second hand from a scrap yard for a couple of quid ! or a new one from ford for i think about Ł15 - Ł20
Old Dec 8, 2004 | 05:36 PM
stusfesta's Avatar
stusfesta
ok thanks, ive just gotta find the thing now!
j.hammond1
30
Oct 31, 2021 05:28 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Archiejay
Aug 12, 2015 12:07 PM
fatboy billy
Aug 3, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
