removeing door pins
Old Mar 4, 2009 | 10:08 AM
stembo21's Avatar
stembo21
Default removeing door pins
i have some fiesta door and they have been cut off with tha hinge still on i have been trying to get the door pins out but they wount move is there a way to get them out?
Old Mar 4, 2009 | 05:37 PM
stembo21's Avatar
stembo21
anyone
Old Mar 4, 2009 | 05:39 PM
BigErn's Avatar
BigErn
older ford door pins are usually a cunt, we tend to just unbolt the hinges from the body when taking a door off.
Old Mar 4, 2009 | 05:42 PM
studabear's Avatar
studabear
big hammer, with a good punch, had to do my cabrio's when having doors repaired, could unbolt bottom but had to take pin outta the top 1
Old Mar 4, 2009 | 05:57 PM
crazycage's Avatar
crazycage
you cant unbolt the mk3 fiesta ones there welded. the top pin is the easy one as you hit it down but the bottom one needs to be twated up and its a cunt.
Old Mar 5, 2009 | 05:16 PM
James998's Avatar
James998
I had to change the door pins on my drivers door about 6 months ago, they were a complete and utter cunt to do, the bottom one was WELDED in and had to be drilled out, you cant get a drill in at 100% the right angle so even now the door has a tiny bit of play in it, but cant be helped.
Bearing in mind i tried hitting, smacking, beating, abusing, oxyacetelene and even swearing and it wouldnt budge, so i resorted to a trusty drill.
Also, this was on a 2000 W reg fiesta.
Old Nov 1, 2009 | 09:00 AM
foolish66's Avatar
foolish66
I have an H reg 5 door ford fiesta, I don't know if thats a mk2 or mk3 and I have to replace the front nearside door, any idea whats the best way? pins seem a nightmare
Bailes1992
Sep 3, 2015 02:17 PM
Aug 29, 2015 08:16 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
no1trancefan
Aug 4, 2015 12:48 PM
