plenum spacer
Old Feb 26, 2009 | 10:25 AM
2wd saff cos @ stage 3's Avatar
Default plenum spacer
hello everyone, im new to the site.
i have a 2wd saff cossie running stage 3.
i have seen plenum spacers on ebay and wonderd is it worth me buying one?
have not found anyone yet that no's much about these.
any help is appreciated.
thanks.
Old Feb 26, 2009 | 09:47 PM
forevaford's Avatar
forevaford
not too much help to ya mate but im using 1 on mine. 10mm.
Old Feb 26, 2009 | 09:48 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
TBH I would just fit a 4wd plenum instead.
Old Feb 27, 2009 | 06:41 AM
im looking at the 10mm one. do's it make the car run better? do's it give more power?
thanks for your help
Old Feb 27, 2009 | 08:13 AM
Rax's Avatar
Rax
Cant see a spacer doing much to be honest.The restricting factor on a 2wd plenum is the elbow so you would be better off putting a 4x4 or a Escos one on.
Old Feb 27, 2009 | 08:47 AM
TurboShed's Avatar
TurboShed
Cossiemodo
If you're at Stage 3, I presume you're talking Green injectors and T3 or T34, and you wanted to spend more money for more power, you'd be better going to Grey injectors and different chip (or Siemens injectors etc.).
You get my drift I hope.
Probably best you start by saying what your spec is at the moment.
Old Feb 27, 2009 | 09:16 AM
why a 4wd mate?
Old Feb 27, 2009 | 09:17 AM
ive had the elbow bored out
Old Feb 27, 2009 | 09:19 AM
yes your rite greens, 3 bar map sensor ect ect but only on t3 at mo, i didnt want to go silly power to be honest t34 would be my next step
Old Feb 27, 2009 | 09:42 AM
grcossie's Avatar
grcossie
4x4 is also restricting in the elbow, ST have better plenum
Old Feb 27, 2009 | 08:53 PM
Rax's Avatar
Rax
ST ??
Old Feb 27, 2009 | 09:54 PM
jon@work's Avatar
jon@work
ST ??
escos Small Turbo
Old Feb 28, 2009 | 10:26 AM
Rax's Avatar
Rax
Ah I see lol.I was just going off what I had been advised to use,4b or escos<didnt state from which and a ec4 throttle body.These were to go with 55lb blacks and a 34 plus a few other bits.
Old Mar 1, 2009 | 08:31 PM
LHD220Turbo's Avatar
LHD220Turbo
thanks.
for the gain of BHP per £££ it isnt worth it in my opinion
if you do fit a spacer, you will alter air flow which will affect fuelling - therefore you'll need a new chip
you cant just fit a new spacer and get more power.
a 4x4 inlet is better than a 2wd and a small turbo escort cossie inlet is by far the best standard inlet on any cossie - but good look finding one, they are not easy to come by and they cost a fair bit
Old Mar 2, 2009 | 03:58 PM
hi there, thanks thats a big help, will a 4x4 inlet fit straight on?
i got those wheels on my car they look amazing
Old Mar 2, 2009 | 06:12 PM
LHD220Turbo
yes a 4x4 will filt no problem - however you will probably need a new chip or at least need to get the fuelling checked on wideband as you will alter the air your engine will flow
if you just fit a new 4x4 inlet without getting it checked/ set up, you'll risk blowing up your motor
Old Mar 3, 2009 | 04:15 PM
i need to get the car set up any way as been sitting for few months and i have changed few bits.
i'll contact few tuners/specialists and see what chip they reccomend.
Old Mar 3, 2009 | 04:28 PM
LHD220Turbo
dont go to just any so called specialist; ask on here first and we can point you in the direction of someone decent
Old Mar 3, 2009 | 04:46 PM
ok who do you reccommend?
i been told m a developments is good and torque of the devil
Old Mar 3, 2009 | 07:23 PM
Paul_RS's Avatar
Paul_RS
The RS 500 inlet is the best standard fit one out there
Old Mar 3, 2009 | 09:14 PM
LHD220Turbo
very true, but they arent obtainable for most people! - your looking at £850+
Old Mar 5, 2009 | 04:27 PM
i dont want to spends loads of money so thats out the question.
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
