removing shafts from box
Old Feb 23, 2009 | 04:59 PM
kye365's Avatar
kye365
Default removing shafts from box
hi everyone just need some advice on how to remove the driveshafts from a ib5 gearbox on a sportka
Old Feb 23, 2009 | 06:20 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Just lever them out.
Old Feb 23, 2009 | 10:22 PM
kye365's Avatar
kye365
lol thought it was harder then that haha.
Old Feb 24, 2009 | 01:13 PM
Dangerous Malcolm..
They've got snap rings on the end which sit in a groove in the gearbox, they just need a short sharp wack with the palm of your hand on the lever.
Old Feb 24, 2009 | 04:18 PM
JesseT's Avatar
JesseT
As a hint, the right side is much easier to remove first with a lever or even two large screwdrivers from opposite sides. After that, the left one can be removed by tapping with a long pin from through the right shafts hole through the box.
Old Feb 24, 2009 | 04:22 PM
kye365's Avatar
kye365
am i right in thinking that i will lose all my gearbox oil?
Old Feb 24, 2009 | 05:46 PM
JesseT's Avatar
JesseT
Most of it, if you don't drain it first.
Old Feb 24, 2009 | 05:48 PM
Dangerous Malcolm..
Try and remove as much as you can fella, you just need a sucky sucky thing through the filler hole.
matman
Sep 9, 2015 05:45 PM
muffster
13
Sep 3, 2015 09:40 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
