Cologne 2.9i 12v still Help with wiring
I am fitting cologne 2.9i 12v from a late granada scorpio. Need help with the wiring. I have complete engine loom and relay box. Lamber sensors, maf sensor. Any help with which wires need connecting from the 2 multiplugs would be grateful.
Thanks
Stuart
Thanks
Stuart
The best man to speak to is neil crane shepard of caprisport he has done alot of these conversions and is very helpful.
www.caprisport.com
email: caprisport @tesco.net
www.caprisport.com
right here we go please help
what do they do (all from ecu)
pin 19 - black & green
pin 15 - blue & brown
pin 34 - brown & yellow & 2 white squares
pin 21 - brown & white
pin 53 - brown & red
pin 3 - yellow & thin brown stripe
pin 10 - black & yellow
pin 30 - brown & white
what to do with white plug from fuse box
![](http://i293.photobucket.com/albums/mm50/stucapri29iTT/DSC00140.jpg)
brown & 2 green squares goto pin 40 on ecu
brown goto pin 60 ecu
brown & green with 2 white squares goto pin 54 ecu
red & blue goto pin 22 ecu
blue & black goto pin 1 ecu
black goto pin 37 ecu
black & 2 yellow squares goto pin 57 ecu
from the engine plug
where do they go
![](http://i293.photobucket.com/albums/mm50/stucapri29iTT/DSC00139.jpg)
pin 9 - brown and white
pin 12 - brown and green
black plug from the fuse box
![](http://i293.photobucket.com/albums/mm50/stucapri29iTT/DSC00142.jpg)
black with 2 green & 2 white squares runs to pin 3 dizzy plug
black with 2 white squares run to + side of the coil
green plug from fuse box
![](http://i293.photobucket.com/albums/mm50/stucapri29iTT/DSC00143.jpg)
![](http://i293.photobucket.com/albums/mm50/stucapri29iTT/DSC00146.jpg)
black goto pin 3 on engine plug
red & black goto a lamber sensor plug
red & black with 2 white squares goto a lamber sensor plug
unknown plug
![](http://i293.photobucket.com/albums/mm50/stucapri29iTT/DSC00145.jpg)
black & green wire from 2 knknown plugs goes to pin 4 on the dizzy plug
green going into the coil leads
thanks stuart
where do they go
unknown plug
thanks stuart
Resident Wrestling Legend
your problems start with the fact that you've got the cat loom from the facelift cars
then you've got the hydraulic lifter engine, so it might benifit from a hot cam right from the off
i think i've got the diagrams kicking about somehwere, i'll see if i can scan them for you
yup, know the one, can't see the pics but as soon as you said "hite plugs" i knew what you were talking baout
get the fusebox and plug everything in, it's all very basic as it's all there, all you need to do is run some power there, there's a wire for the fuel pump and one for ignition live feed to the ecu and one for the rev counter
you only need the fusebox on the passenger side, the long one with 3 rows of fuses in it
hi mate any luke with the diagrams..
thanks stuart
thanks stuart
hi just wondering if any one knows i have a 2.9 12v and wiring in a megasquirt 1 v3 at the mo the only problem i have is there is 1 wire that comes from the ecu that sheethes into 2 that goes to my dizzy what wires do i need to connect them to,theres 5-6 wires on the dizzy so a bit stuck
hi all got my mgasquirt all wired up but i seem to be having another problem everything works fine the fuel pump kicking in with the ecu i have spark etc etc the only think i dont have is injector pulse on turning over i get 1 squirt when i turn the key off any 1 got any ideas,also does any 1 know what the wires on the tfi module actualy do i have
blue/yellow
blue/red
black/green
black
green
blue/black
if any 1 knows let me know please just so i can double check my wiring
blue/yellow
blue/red
black/green
black
green
blue/black
Mark RS
12-10-2015 06:01 AM
