bit of a silly question regarding baterys
i was planning on putin it into a renault 5 turbo..if i get one again
i think its on the books iv seen one i really like and iv always had a love for the 5sssssssss
It depends on the age of the car, and whether it is meant to have a CALCIUM battery, if it is, then it will have a higher charge rate, and certainly 14.8 minimum, whereas on non calcium cars it will be regulated to 14.4 maximum, some calcium cars charge at 15.5 -16 volts.
There is no bother of course fitting a calcium battery on a car not equiuped new with one but must not put a normal non calcium battery on a car that orignially had a calcium one.
If you do it would just kill the battery, but R 5 is std non calcium.
rog
04-09-2015 12:10 PM
