Cossy Oil Pressure
Old Feb 12, 2009 | 09:06 PM
cozziepj's Avatar
cozziepj
Default Cossy Oil Pressure
my cossy oil pressure at idle is about 29psi cold and drops down to about 22psi when warm, im told thats 2 low, is it worth taking crank out inspecting and replacing shells?
Old Feb 12, 2009 | 09:11 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
that is a bit low, shouldnt be below 26 warm, is your engine rattly or tappy?
Old Feb 12, 2009 | 09:20 PM
cozziepj's Avatar
cozziepj
no its not rattly at all cold or warm so suprised it drops soo much when it warms up unless its got crap oil or sumthin???
Old Feb 12, 2009 | 09:27 PM
Tev's Avatar
Tev
that does seam a bit on the low side fella, mine engine's rattles and knocks like fook but on cold start up i get bout 45-50psi n when warm on idle its around 30psi
Old Feb 12, 2009 | 09:29 PM
lawnsy's Avatar
lawnsy
mine was 50-55 cold and 30-35 warm on tick over
Old Feb 12, 2009 | 09:31 PM
cozziepj's Avatar
cozziepj
ok, myns def low then!! what you recommend new set of shells before i get any damage dont wanna have to grind the crank, or could it be shitty oil or wrong grade?
Old Feb 12, 2009 | 09:36 PM
lawnsy's Avatar
lawnsy
mine was oil pump pickup pipe blocked with silicon...
Old Feb 12, 2009 | 09:39 PM
cozziepj's Avatar
cozziepj
im gonna have to inspect it dont want it to start chapping, would be good if it was just dirt in the pickup pipe
Old Feb 13, 2009 | 11:12 AM
I would try a different pressure gauge first, as you don't want to be doing a tear down just for a dicky pressure gauge!!
Personally, so long as it is ok whne above about 2000 rpm I would leave it alone, there is such little load at idle this pressure is no problem at all.
The ford figures assume that everyone will just buy a new engine from them, that pressure is perfectly adequate, some engines fall off the bottom of the scale on tickover, but pick up once spinning a bit faster.
Yes wrong oil, ie too thin will lose pressure as it's still thinner when hot, so will worn pump blocked strainer etc.
I would try an oil change first with at least 50 weight oil, ie 5W/50 or 10W/50 etc.
Old Feb 13, 2009 | 06:01 PM
cozziepj's Avatar
cozziepj
Smile
thanks for that tabetha thats a relief i will give the oil a change this weekend since its due a change anyway, n borrow a gauge of a mate to check and go from there
Old Feb 13, 2009 | 06:15 PM
TurboShed's Avatar
TurboShed
Cossiemodo
I'm with Tabetha on this. It might have the wrong grade in it - you don't mention what oil is in it, I assume you don't know?? Did you buy the car recently or something?
Old Feb 13, 2009 | 06:35 PM
cozziepj's Avatar
cozziepj
yeah its not long mine, so got no idea whats in it, the last owner only did 600miles in it so cant see him knowing what oils in it either!
Old Feb 16, 2009 | 10:02 PM
saph cos rob
swindon rsoc
ah yes i forgot to say ford recommend 20w50 oil!! so you want to be running a heavier oil i run 15w50 mobil1 and its 70-75 cold 30-35 hot..... if its not rattling or tapping when warm i wouldnt worry too much!
Old Feb 19, 2009 | 10:30 PM
cozziepj's Avatar
cozziepj
i put insome fresh oil 10w 40 until i get some of the 50 stuff and thats put the oil pressure up a bit, seems to be fine but gonna keep an eye on it and listen out for any knocks
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
dombanks
Sep 21, 2015 08:38 PM
Thanasis
Sep 7, 2015 07:33 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
