A bell jingling like sound from the engine on acceleration...
Right, in my ERST when im in a high gear like 5th and doing 30mph its fine just cruising.
But if i go to accelerate fast or slow it starts to make a slight jingling sound until im at about 45mph.....
Is this because im in too high of a gear at that speed or is something wrong? It doesnt drive any different...
Its fine if im in 2nd or 3rd... just 4th and 5th...
But if im in 4th the jingling stops at at about 38mph...
Its not mega loud but i can hear it.
Thanks.
Thanks.
Like i said its fine in 1st, 2nd, 3rd at relative speeds. But when the car is at about 25 - 30mph and you accelerate in 5th gear until it reaches a speed of say 45 it jingles.
But its fine when its at a constant speed of 30 and your not accelerating just cruising.
It has been setup by MSD.
but to be safe get the timing and afr checked underload, as things could of changed since MSD set it up, such as vacuum leak, or fuel pressure etc.
Dave R.
All it takes is for the dizzy to move a nats todger amount, sure all fuelling will be spot on as stu did it, but other things may have been moved inadvertantly.
So ill see tomorrow. But in modern cars if your in to high of a gear at low speeds it jugs doesnt it.
The noise that people say about their RS's sounding like transit vans when they rev to 4000rpm.... and people say its pinking???
well if i rev mine all the way it sounds like a 1ltr being ragged but not like a diesel?
Is that just normal.... its hard to hear over my 4" mongoose.... but can hear it...
Just had a mates verdict on it.
He said its defo pinking.
I had it setup by MSD when i first got it. Didnt really tan it and kept it undercover for months. I had it booked in like 2 weeks after the set up for a health check because it was overboosting which wasnt good. Had a problem with the car starting (fuel pump) so put it under cover and left it.
Got it out just before xmas again and now its pinking and still overboosting but never did this before it went to MSD...
Gonna have to have it booked into MSD now and checked at...
Why does it need remapping just cos its pinking?!! doesnt mean its the map by a long shot. If the fuel pump was a problem after they did the work how is it definately their fault its now pinking?! if you have changed or done anything to do with the fuel pump the fuel pressure can be affected to how it was when they set it up therefore needs setting up again which isnt their fault!!
Shizzle My Nizzle
Thanks.
Thanks.
Are you a taxi driver
"Right, in my ERST when im in a high gear like 5th and doing 30mph its fine just cruising."
I wonder what the problem is? Im going to go down on Friday and see if i can get it booked in for them to look at. I have my original report here anways so ill take that with me
Joys of turbo cars mate!!! I drove from brighton to MSD a few years ago and got stu to set up my cossie, few things were wrong but he got it running as best he could and she was flying on the way home ran loads better for ages till i planted it and lit the back wheels up and turbo peaked at some silly psi!!! pulled over and found the actuator pipe randomly had split so was running unlimited boost!!! No ones fault just one of those things, was fine when i left
Well Stu is seeing it Tuesday
Thanks fellas.
The driveability low down is down to mapping, if too far advanced etc this will exacerbate the jerking low down.
Depending on spec, most mapped cars can run to idle speed in top with no lugging, or acceleration to speak of either!!
gchristophi
31-08-2015 10:36 PM
JoeyBoyden
18-08-2015 10:52 PM
track.focus'd
12-08-2015 05:53 PM
blakey100
04-08-2015 08:17 PM
