series 2 starting problems
Old Feb 9, 2009 | 06:17 PM
ALEXrSt's Avatar
ALEXrSt
Default series 2 starting problems
HI THERE I WOULD BE REALLY GREATFULL IF PEOPLE COULD FROW SOME IDEAS MY WAY !!
RIGHT FROM COLD IT WILL START AFTER ABOUT 10 SECONDS AND WHEN IT DOES FIRE UP IT RUNS LUMPY FOR A MINUTE OR TWO THEN ONCE ITS RUN FOR 10MINS OR SO IVE GOT A 50/50 CHANCE OF IT STARTING ON THE KEY OTHERWISE I HAVE TO PUSH START IT TO GET IT RUNNING,
IVE RECENTLY CHANGED THE CAM BELT AND ITS GRADUALLY GOT WORSE SINCE THEN ? ITS RUNNING KENTCVH35 CAMS IVE TIMED IT UP TDC[IMG]file:///C:/Users/ray/AppData/Local/Temp/moz-screenshot.jpg[/IMG] BUT I DON'T THINK IT WAS BEFORE SO COULD THIS BE PLAYING WITH THE WAY ITS BEEN SETUP BEFORE I DONE THE BELT
Old Feb 9, 2009 | 08:09 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
could be there is no pic so i'm presuming its got vernier pully and as its running better cam i would assume that it might of had a amount of degrees of advance on the cam
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
marky_g
18
Aug 26, 2015 03:42 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
