catter with dumpvalve
Old Feb 4, 2009 | 08:22 PM
CHUNKYS RS's Avatar
CHUNKYS RS
Default catter with dumpvalve
should i still get a little bit of chatter with a dump valve fitted
if i boost up and lift off sharply i get dump valve niose and no chatter but if i boost and lift off slowly i get chatter with no dump valve niose does this mean the spring in the dump valve is to strong
(frst t2 14psi)
Old Feb 4, 2009 | 08:23 PM
KSA-Cossie's Avatar
KSA-Cossie
My saph chatters then dumps. 36 psi though lol.
Old Feb 4, 2009 | 08:32 PM
CHUNKYS RS's Avatar
CHUNKYS RS
thanks for rubbing that in
Old Feb 5, 2009 | 10:04 AM
percybigun's Avatar
percybigun
Twistin me melon man
same here i get chatter and dump, T28 at 19psi.
a group A cossy filter helps with chatter noise, but maybe your turbo is a bit small to do both sounds?
Old Feb 16, 2009 | 11:46 PM
siward's Avatar
siward
I also get chatter and dump but mainly chatter and its loud, Only running 5psi at the moment too, Its a t34 with group a k&n filter
Old Feb 17, 2009 | 09:40 AM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
you will get the same chatter as with not using a dump valve, the way to do it is let your foot off the throttle slowely then it will chatter without the dump valve, if you lift straight off the vacuum opens the d/valve allowing the air to escape meaning it wont reach the turbo to cause it to sltall/chatter. sounds really boy racer'y but you cant help but do it.lol escpecially when there is people aroung.
Oh the joys of owning a turbo (makes every 30yr old 17 again )
Old Feb 17, 2009 | 11:25 AM
Daz Gti's Avatar
Daz Gti
last bit very true and yeah i cant help but lift off slowly past people with mine being a sleeper
Old Feb 17, 2009 | 07:32 PM
Smartdj.'s Avatar
Smartdj.
i had this problem with my renault 5..turns out i had the wrong d/v on there
Mr.Ford
Ford Escort RS Cosworth
Apr 4, 2005 12:07 PM
Stavros
Jan 4, 2005 02:11 AM
wimwerf
18
Sep 24, 2004 12:50 PM
wimwerf
41
Sep 14, 2004 12:31 PM
M2YLE
Sep 12, 2004 09:48 PM
