Fitting a kent engine into a cvh mk3 escort.
Old Feb 2, 2009 | 03:04 PM
curlie467's Avatar
curlie467
Default Fitting a kent engine into a cvh mk3 escort.
Could i fit a kent engine into a cvh engined mk3 escort, i think its a straightforward swap but am wandering about engine mounts, anybody come across this slightly obscure swap?
Old Feb 2, 2009 | 06:00 PM
I'm sure the 1100 valencia engine was fitted by ford so should be no problem.
Old Feb 3, 2009 | 11:52 AM
curlie467's Avatar
curlie467
Yes it was, thats why i thought it would be fairly straightforward, what i was wandering was whether i need the 771 fwd block or whether the 711 rwd block would fit as i know that the mounting casts are different.
Anybody shed any light?
Old Feb 3, 2009 | 12:11 PM
Ade's Avatar
Ade
Fast Ford snapper
Think the mounts are different..... MK1 XR2 block might be a good starting point as it probably slots straight in unless you're wanting to fit something you've already got?
Old Feb 3, 2009 | 12:41 PM
curlie467's Avatar
curlie467
The cvh in the car is not in the best of health, what i was thinking was to locate a 1300 x/flow and lightly tune it, it wont be far off the power of the cvh plus i can get the car into the lower tax bracket!
Just a thought really, any advice or feedback as to pointless or a good idea would be greatly received.
Old Feb 3, 2009 | 01:28 PM
Ade's Avatar
Ade
Fast Ford snapper
I doubt there would be any real advantage in using an old 1300 X-flow over a 1300 HCS valencia which would be a lot easier to source and fit..... it would probably be slower too!
Not sure how you go about having a car regraded to a lower tax bracket, might need inspected?
I quite fancy doing a bored out long stroke Valencia on bike bodies myself!
Old Feb 3, 2009 | 05:29 PM
curlie467's Avatar
curlie467
Apparently the dvla require a receipt for the engine or a garage inspection, it would then be officially changed on the log book and recognised for the cheaper tax.
Is the valencia the 1.3 from mk3 fiestas?
You can get the X flow up to 1988CC using south african AX block and stroker crank, lovely combo.
Old Feb 4, 2009 | 08:38 AM
Ade's Avatar
Ade
Fast Ford snapper
And Mk4 Escorts/Orions 88-90. High compression swirl engine, runs a twin choke weber, (TLDM).
Sultzi
12
Aug 16, 2015 01:08 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
knight19770
Aug 4, 2015 12:36 PM
